Space Saver Tyre for 17inch
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius NZ, Aug 4, 2013.
  1. Prius NZ
    Prius NZ Junior Member
    70
    27
    Auckland, New Zealand
    My Prius came with factory fitted 17inch wheels complete with low profile tyres. Instead of a spare wheel I have a compressor repair unit. Does anyone know if there is a space saver wheel i can get and will fit in the spare wheel space? Not very keen on this complicated repair kit.
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    If you can chase down a 15" Prius spare from a wreckers it will serve. The total diameter, i.e. with rim plus tyre, of the 17" is slightly less than the 15" tyre.
  3. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)I purchased one (new) off eBay for $100 with shipping.
  4. Mike500
    Mike500 Senior Member
    2,593
    764
    It's the same spare donut provided to late model Corollas.
  5. Mendel Leisk
    38,704
    Ours has the 17" tires, and the temp spare. As far as I know there's nothing special about the spare, ie: it's the same as spare that comes with 15" tire models.
  6. Prius NZ
    70
    27
    Yes. I have done some research and found:
    Prius takes a 195/65 R15 tyre
    Prius i-Tech 215/45 R17 tyre
    Space saver T135/80/16R tyre
    They all have the same outside diameter.
    Now all I have to do is find one
