Space under the doors
Discussion in 'Newbie Forum' started by Bgmacon, Jan 5, 2013.
  1. Bgmacon
    Bgmacon Junior Member
    16
    Asheboro, North Carolina
    Dust and air comes in under the doors in my 2012 Prius.....when I spray my car off water does as well...what is a good seal to put there to fix this?
    49,492
    sounds like your seals aren't working properly. i would have the dealer look at it, should be under warranty.
  3. mikefocke
    3,701
    1,648
    Sanford, NC
    Don't you all get dirty door sills? I do. That indicates intrusion.
    Having a v, I also get an extraordinary amount of dirt collecting just below the rear window on the ledge. But that is external and cause d by the Kamm effect and the collection of condensation from the window also collecting there.
  4. katozo
    katozo New Member
    sc
    Dirt on the door sills is annoying and so is the dirt that collects under the rear window. I love the way the car drives and the great fuel mileage, but the dirt is ugly. Everytime I put something in the back of the car, my hands get dirty!
  5. bisco
    49,492
    dirt on the door sill is prior to the seal. dirt, air and water coming into the car is another matter.
  6. scotman27
    scotman27 Active Member
    735
    81
    PA
    2001 Prius
    Yeah really. That I would most definitely have the dealer service that. thats ridiculous, a brand new car and your getting dirt and water intrusion inside due to faulty sealing of the door/window, whether the door needs adjusting or maybe the weatherstripping replaced. they should cover that. for what you probably paid for that car, i would want it right not half-vast
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The water doesn't get inside the car. It collects on the lower sill plate. It is annoying but it is not destructive. :)
  8. Mendel Leisk
    38,727
    The OP's not clear, it could be there's something wrong with the gasket along the bottom. Or not.
  9. doucoc
    doucoc New Member
    2013 Prius v wagon
  10. doucoc
    doucoc New Member
    2013 Prius v wagon
    Space under the doors must be a common problem. During a heavy rain recently water came in under the doors and completely saturated the carpet, both front and rear. Carpert has to be removed and replaced. Local Toyota dealer, Palm Beach Toyota, is charging $1,600 for the job!!!
