Spare physical key -- any point?
Discussion in 'Gen 3 Prius Main Forum' started by NewHybridOwner, Mar 1, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Is there any point in carrying-- separately from the electronic fob -- a spare physical key, as I have done for other cars? I went to a good locksmith who was prepared to sell me a whole remote and physical key for $275, but said they would have to order key blanks and cut them for $30 each. They don't stock the blanks "because they're useless without the fob."
    Comments?
  2. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
    You can buy a physical key on ebay and comeback to locksmith
  3. audiodave
    audiodave Active Member
    800
    272
    US
    You can buy a new fob housing with a key you'll need to have cut. With this i think you can drive the car.
  4. audiodave
    800
    272
    US
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    With a spare physical key, at least you can open the door and get inside. I know you can't drive it, but that's better than waiting outside of the car for help to arrive when raining or very cold.
    Pluggo likes this.
  6. bisco
    52,390
    No, no point
  7. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    If you carry a separate keychain, why not just remove the physical key from the fob and put it on the keychain with your other keys?
  8. NewHybridOwner
    607
    283
    W. Michigan
    But the only provision made for attaching the fob to a keychain is by means of the hole in the head of the physical key. If I keep the physical key in my wallet, there's no way to attach the fob to the keychain -- unless I just use an uncut key from eBay as a means of attaching the fob to the keychain.
  9. NewHybridOwner
    607
    283
    W. Michigan
    That's a good point.
  10. Mendel Leisk
    41,901
    And pocket lint will be getting into the fob easier.
  11. bisco
    52,390
    and belly button lint
    RMB likes this.
  12. Johnny Cakes
    Johnny Cakes Senior Member
    1,057
    785
    Virginia, USA
    I travel frequently and am always scared that I'm going to lose the key fob, thus leaving my stranded in the middle of nowhere.
    So I hide a physical key outside on the car. I then have the FOB in a small Faraday bag hidden inside the car. With this setup, I can never be stranded.
    And while I'm stupid enough to lose things like keys, I'm smart enough to find great hiding spots so that no thief is ever going to find either the spare physical key hidden outside the car nor the fob inside the car.
    Bay Stater and bisco like this.
  13. NewHybridOwner
    607
    283
    W. Michigan
    My fob, with the physical key, on the same key ring as all my other keys, is always on my person: on my belt or in my pocket. If I were to leave the fob in the vehicle I wouldn't be able to lock it. If the car were left locked outside rather than in the garage, and I locked the door behind me as I left the house, leaving the keys in the house, then I could find myself unable to unlock and drive the car. BUT I can't lock the house door behind me without the key, AND I can always get back into the house through the garage using the pin code.
    So the only use I can see for having a spare physical key in my wallet is to deal with the situation somebody mentioned upthread: it would enable me to get into the car to wait for help in the event of a breakdown involving an electrical system failure that disables the electronic unlocking capability.
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I recommend having a spare mechanical key to get into the car. And a spare fob (or even just the circuit board from inside the fob) somewhere inside the car. Take the battery out of the spare fob to prevent corrosion and interference with normal usage. A batteryless fob/circuit board can beheld up to the POWER button to unlock the ignition.
    Bay Stater likes this.
  15. gliderman
    gliderman Active Member
    751
    225
    How many fobs can be paired with a prius? Just curious.
  16. RobH
    RobH Senior Member
    2,385
    991
    70
    5 on Gen2, 7 (?) on later.
  17. rjparker
    rjparker Tu Humilde Sirviente
    10,505
    6,594
    Texas Hill Country
    A separate key will allow you to leave the car running and locked with the ac running as you run into a store.
    Johnny Cakes likes this.
  18. NewHybridOwner
    607
    283
    W. Michigan
    That isn't illegal?
  19. rjparker
    10,505
    6,594
    Texas Hill Country
    It varies by state and even city. In Texas it is illegal on a public street to leave the car running (eg in ready mode for a Prius) but you can run it on private property. It is primarily an anti-theft concern aimed at people who warm up their cars in the morning with the key in the ignition. The Prius won’t let you lock the doors from outside the car when in “ready” except manually with a key. I see people who leave dogs in a running car or truck and others like delivery persons who don’t want to cycle their cars all day.
  20. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    People here jumped on my case when I said the same thing. I typically shop in the early mornings so I know the check out lines are shorter to return back within 5 to 10 minutes, most of time there's no lines. Oh the outrage poured in when I mentioned that. My trips are short in distance, no AC and I engaged parking brakes all the time.
