Spare tire, Compatibility, Donut vs whole wheel
Discussion in 'Gen 4 Prius Main Forum' started by ms2000, Feb 17, 2025.
  1. ms2000
    ms2000 New Member
    sunnyvale
    Acquired a 2017 Prius 4. It does not have a spare tire.
    Which wheels from Toyota or another fits this car.
    I learned that I can store a full wheel but can not keep the regiform material in the trunk.
    It has 196 65R15 wheels.
    Which prius model years wheel fit this car?
    What is everyone doing? How much does it cost?
  2. ms2000
    ms2000 New Member
    sunnyvale
    Typo 195 65R15 wheels
    Also what is the significance of the 7th and 8th character from the VIN? Mine are FU
    #2 ms2000, Feb 17, 2025
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,056
    539
    Tucson, AZ
    2021 Prius
    Welcome to PriusChat. You might start looking here. There were 267 replies to that thread. For the most part we don't talk about the need for a spare tire. It's a Murphy's Law sort of thing, bringing up the possibility of a flat tire, and none of us want to increase that probability. If one wants to be logical about this, look back over X number of years of driving and add up the number of flats you have had. Massage the data with weighting toward the very recent past with newer tire designs and maybe less junk on the road. You will find that a flat tire is relatively improbable. Now I'm going to have to throw some salt over my left shoulder and walk around my chair three times to dismiss the temptation I just let go. If you need more info try the search function at the top of the page. Click in the search box, then toward the bottom of that little window click on the more... button and narrow the search to the Generation 4 thread. Cheers.
  4. DIY gen3
    DIY gen3 Junior Member
    Paducah, KY
    2020 Prius
    I know when I bought my 2020 LE, that only the LE came with the spare tire and the fitted foam to store it nicely. It may be true in other years. So if you can find an LE in a salvage yard that would be one way. If I remember correctly from postings, to order a new spare and fitted foam was about $2,500
