Spare tire size .. ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sp00ky, Oct 17, 2012.
  1. sp00ky
    sp00ky Junior Member
    23
    Sweden
    Hi all,
    We in EU does not have spare tire in trunk, we have compressor kit instead. I'm planning to throw out compressor kit and mount spare tire instead.
    I'm wondering can I just buy standard 15" alloy 195/65/15 and mount in trunk or I need to buy some special Toyota models (t.ex. 125/70/16 donut) to fit in trunk ?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    My car came with a space saver spare, and it's a tight fit, so I don't think a standard size tire/wheel would fit.
  3. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    My JP Gen3 Prius (195/65R15 standard) has T135/80D16 spare tire.
    Ken@Japan
  4. Selzier
    Selzier Whee!
    148
    51
    Hi Spooky,
    A regular 15" won't fit. I learned this when I had to swap out a flat for my spare and realized that my OEM 15" did not fit in the wheel well. (both the diameter and width of the wheel were larger than what the well is designed)
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The reason you have "D" rings and the nylon strap is the -flat- tyre you just removed won't fit where the spare donut came from. It must be strapped down on the hatch floor. So no, a regular wheel/tyre won't fit under the hatch floor. Now, if you want to try, deflating it might help, but it will still be very tight!
  6. sp00ky
    23
    Sweden
    Thank you all for answers, even "donut" spare tire will be better than compressor-kit.
  7. bisco
    49,488
    yes. we don't get donut with pip and many are buying them from recyclers. and we don't have the spare well either. we did get the straps.:)
  8. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    I got the space saver spare tyre just recently to replace the repair kit.
    Part#
    42611-20A50 - Wheel, Disc
    42652-30340 - Tyre Tubeless
    51931-47010 - Carrier Spare wheel (this is the nut that holds it down into the wheel well).
    davekro likes this.
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Where is the thread on the exterior rear tire kit mount?
    Thanks,
