Spark plug comparsion
Discussion in 'Gen 3 Prius Main Forum' started by Kapana91, Oct 15, 2024.
  1. DENSO 4711 Iridium TT
  2. DENSO 3499 Iridium Long Life
  3. NGK 4912 Laser Iridium
  4. NGK 95993 Laser Iridium High Ignitability
  5. NGK 92274 Ruthenium HX High Ignitability
  6. NGK 97292 Ruthenium HX High Ignitability
Results are only viewable after voting.
  1. Kapana91
    Kapana91 Junior Member
    georgia
    oem recommended is DENSO 3499 Iridium Long Life, but all these spark plugs also good
    Share your opinion on which spark plug is better in which situation
    50,881
    my opinion is that there are too many counterfeit plus out there to risk not buying from a dealer.
  3. Kapana91
    georgia
    I am going to order from rockauto
    But I can't decide which one to buy, my car has 80k miles on it, what would be the best for short trips, fuel economy and engine performance?
  4. Eddie25
    Eddie25 Active Member
    465
    189
    IL
    No one can reliably tell you that. I’ve tried the first three on the list because I changed mine multiple times (after getting counterfeits, after clogged intake, and after head gasket job). There’s no perceivable difference between any of em.
  5. ChapmanF
    17,050
    My take would be that the spark plug's job is to ignite the fuel-air mixture, consistently, under all of your driving conditions.
    If plug A and plug B both do that, neither one is better. If plug A does that and plug B doesn't, A is better.
    With a scan tool, you can watch an ECM statistic called "misfire margin" while you are driving—ideally in a range of conditions (datalogging helps). The margin is kind of a sliding scale. Negative numbers are bad news ("in the negative zone, a misfire is occurring"). Positive but under +30 is still "a high likelihood that a misfire is occurring." The farther above +30, the less likely.
    If you've got low misfire margins with plugs you've got now, and new plugs push the margin up into the "well above +30" range, then the new ones are doing the job. IMO, once the job is getting done, a fancier plug is pretty much vanity.
    If you try one style of new plug and see low misfire margins, say dipping below +30, and then you try another style and the margin is better, then stick with that style.
    I think I'd start with the Toyota-specified plug and, if I saw a nice high margin, just keep it and call it a day. I'd look for something else only if the margin showed a problem with the plugs.
    Some of the 'enthusiast' plugs are made with very skinny electrodes. Those do fire more easily, which is a benefit if you have evidence that the ones you've got aren't firing easily enough.
    Otherwise, the skinny electrodes just mean shorter life, and the Toyota OEM tradeoff of a slightly fatter electrode that still reliably does the job and lasts 100+ thousand miles makes sense.
  6. AndyToledo
    AndyToledo Junior Member
    Toledo Ohio
    Toyota uses the Denso brand. I would vote for the 3499 except it seems they are being phased out in favor of the TT technology. I settled on the Denso 4711 4 pack
