Spark plug replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Blake2100, Mar 9, 2020.
  1. Blake2100
    Blake2100 Junior Member
    Kansas
    I plan on replacing the spark plugs on my 2010 prius. The dealer quoted me about $20 a plug. So my question is do i go with this price or buy replacement ones from oriellys/advanced auto, etc.? The NGK one they have for sale are nearly half the price but i just wanted your guys opinion. I just bought my 2010 with solar roof and am getting pretty poor mpg so i started with the pcv and intake cleaning along with egr tube. Next weekend i plan on starting on the egr cooler and plugs. 2010 prius IV almost 160,000 miles. Thanks in advance
  2. Patrick Wong
    18,200
    6,472
    Look on amazon.com and buy the correct NGK or Denso iridium spark plugs for your car. I would expect to pay ~$12 per plug.
    Raytheeagle likes this.
  3. Siward
    Siward Active Member
    296
    124
    Toronto
    Careful of fake plugs. I heard of most of them coming from Ebay and some from Amazon.
  4. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    Don't buy spark plugs from other than a trusted seller.
    There are factories in China producing fake Denso Iridium plugs by the tens of thousands. They are not hard to find (alibaba, etc.).
    I avoid third party sellers on Amazon and ebay for this reason. Be especially suspicious of "Toyota OEM" spark plugs from other than Toyota dealer. Why would these be outside the Toyota network at a great price? Why indeed.
    ColoradoBoo, ASRDogman and TonyGB like this.
  5. TonyGB
    TonyGB Junior Member
    London
    ----UK----
    here in uk you can buy plugs through eBay but from Toyota dealers only, anything else is simply fake, but the packaging is so good that even Toyota can’t said they are not real. Price is the first alarm that rings the bell. Same for Toyota filters too, a lot fake with very good copy boxes.
    Regards
  6. Siward
    296
    124
    Toronto
    I bought my Denso 3444 from RockAuto years ago as part of a bigger shipment which I plan to put in my Prius this spring. The previous ones I got from RockAuto for my Corolla in 2010 were not fake, so I still have some trust in them.
  7. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    Just order from McGeorge Toyota in Virginia, or another dealer, in this case. Each plug is less than $9. As I learned in another recent thread of this same subject, the current Toyota (Denso) plug is updated (hotter) from the original plug listed in the your manual. It's difficult to find otherwise.
    Bbonez likes this.
  8. Blake2100
    Kansas
    Okay thank you
    Michael Wood likes this.
  9. Michael Wood
    Michael Wood Active Member
    179
    118
    Boston, MA
    2020 Prius Prime
    The new gen 3 OEM plug is Denso SC20HR11 per my 2015 owners manual. I guess the old spec was SC16HR11
  10. Mendel Leisk
    38,653
    Other way ‘round.
  11. Michael Wood
    179
    118
    Boston, MA
    2020 Prius Prime
    So the SC16HR11 is the hotter plug? Do you know what year (approx) they made that change? I guess that explains why none of the dealers are stocking the SC20HR11.
  12. johnHRP
    johnHRP Active Member
    417
    133
    tally, fl
    The SC20HR11 is discontinued and replaced by SC16HR11 to reduce fouling from oil consumption. You also can get dual tips ixeh20tt similar design as Prius 4th gen and all newer Toyota engines. Denso practically replaces a single Iridium tip with dual tips for all newer Toyota for better efficiency with similar lifespan of 120k miles.
  13. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    So...
    1. Are we talking Gen 3, or Gen 2?
    2. Anyone ever connect the dots and say hey increased heat -> increased warped head gasket?
    (I'm very loyal to Bosch from many European cars in the household and they list a 96339. Anyone know if this is a good option?)
    REVVL V+ 5G ?
  14. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    Yep, ditto on the fakes....lots out there....I got my new Densos from my dealer.
    Important tip for the DIYers...those plastic clips you have to remove over the ignition coils can be pretty brittle on older cars and are known to break when squeezing the tab to remove. To avoid a nightmare (replacing the connector), use a small flat-head to lift up the tab on the bottom, not the end where you're supposed to squeeze, and gently work it off....this is the scariest part whenever I do this job. I don't even touch that tab...ever!!
  15. OptimusPriustus
    OptimusPriustus Active Member
    308
    131
    Finland
    ”The term hot/cold is commonly used to describe whether a spark plug heats up easily (hot) or whether it provides resistance to heating up (cold)”. Hot plug for low heat engines (like Prius).
    Heat Range - NGK Spark Plugs Australia | Iridium Spark Plugs | Glow Plugs | Oxygen Sensors | Ignition Leads | Ignition Coils : NGK Spark Plugs Australia | Iridium Spark Plugs | Glow Plugs | Oxygen Sensors | Ignition Leads | Ignition Coils
    And no, i never buy any Bosch plugs. Never. Only NGK or Denso.
    Michael Wood and jzchen like this.
  16. Mendel Leisk
    38,653
    Our last car, an '06 Civic Hybrid, had two plugs per cylinder. Interestingly, when I checked them there was one Denso and one NGK at each cylinder.
  17. OptimusPriustus
    308
    131
    Finland
    To minimize risk:)
    Michael Wood and Mendel Leisk like this.
  18. johnHRP
    417
    133
    tally, fl
    Always buy sparkplugs from local shop. Many offer online with coupon orders and pickup locally. Advance autoparts/Carguest, Autozone, ORelley often have online coupons that can be used for sparkplugs.
    NAPA has good parts for brake and suspension parts. Online, Rockauto or A1auto have good deals but not easy for warranty. Local shops are better.
  19. ttou68
    ttou68 Active Member
    345
    203
    Spark plugs are cheaper at your local Toyota dealership than any other options currently..
    I just purchased a few for less than $9 each out of the door recently. YMMV..
    Denso is what I would use on all Toyota vehicles, and it's been couple of years now since the sc16hr11 (90919-01275) take place of sc20hr11
  20. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Did you do that? On purpose?
    REVVL V+ 5G ?
