Spark plug wires
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Stripedshrimp, Dec 19, 2022.
  1. Stripedshrimp
    Stripedshrimp New Member
    24
    Seattle
    Three Touring
    I changed my spark plugs last summer but just realized that I didn't change my wires. Has anyone done this? It seems complicated. It looks like the wires are part of a wire harness. Any pointers would be appreciated. Thanks.
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    What problem would that solve?
  3. Elektroingenieur
    2,515
    3,258
    Three Touring
    All Prius cars have a direct ignition system (distributorless ignition), with a separate ignition coil for each cylinder. The spark plug caps are part of the ignition coil assemblies, so there aren’t high-voltage spark plug wires like those in conventional or transistorized ignition systems of older design.
    Indeed, the wires to the ignition coil assemblies are part of the engine wire harness. Unless there’s a problem that can’t be repaired using the methods described in the Electrical Wiring Diagram (more info), there should be no need for replacement.
  4. Stripedshrimp
    24
    Seattle
    Three Touring
    No problem really, I am just focusing on preventative maintenance.
  5. Stripedshrimp
    24
    Seattle
    Three Touring
    Wow ok thank you!
    This is the info I was looking for.
    Elektroingenieur likes this.
  6. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Replacing that wiring harness would be very expensive, a lot of work. and unlikely to prevent any future problem. Best to leave it alone. The biggest threat some people face regarding the engine wiring is rodents chewing on it.
