Spark Plugs after 110k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alloosh, Aug 26, 2012.
  1. Alloosh
    Alloosh Junior Member
    Jordan
    Hi folks,
    So after 8 months of owning my prius I started to take care of it , so the easiest thing to do was to change the spark plugs, it was an easy job , the only hard part was the last coil connector.
    As you can see in the attached pic , the second has some oil on it from the outside and the last one is rusty, I was a bit scared to see the oil on the plug but after some search it seems to be a minor issue.
    I don't know much about spark plugs , so do they look normal to you?
  2. Patrick Wong
    18,200
    6,497
    The oil is OK. The rust shows you that water has dripped down into the spark plug well. Usually that happens because water drips down from the center seam of the cowl above the engine. Or, maybe someone steam cleaned the engine and got the valve cover wet.
    It would be good if you could prevent water from getting on the engine valve cover, now that you have installed new plugs.
    Your photos do not show the porcelain insulator surrounding the center electrode on the firing end of the spark plug. The insulator should be an off-white or very light brown color and should not have wet oil or gasoline deposits.
    m.wynn likes this.
  3. Alloosh
    Jordan
    Thanks Patrick , it seems that my plugs have some deposits on the insulator , the attached insulator shows the insulator of one of the plugs
  4. Patrick Wong
    18,200
    6,497
    Well, that photo needs more lighting, but it does appear that the ground electrode has an unusual amount of deposits.
    It is possible that very cheap fuel was used by the prior owner. It would be interesting to see what your engine's pistons and valves look like.
    m.wynn likes this.
  5. Alloosh
    Jordan
    You are right , I also hear a fuel injector noise coming from the engine , I live in Jordan ,and although I fill it with Octane 90 , it seems that the fuel quality is not up to the standard.
    Is there any possible recommendation to clean the injectors or do some maintenance to prevent any future effects.
  6. Patrick Wong
    18,200
    6,497
  7. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
  8. 2004priusgal
    76
    new jersey
    Upgrade
    at 160000 mi, my 2004 had similar rust issue....
  9. Patrick Wong
    18,200
    6,497
    Water had gotten into the spark plug well that the rusty plug came out of. That can cause engine misfire.
    m.wynn likes this.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Oil on the outside of the plug is not oK
    You have a leaking valve cover gasket the oil is getting
    Past the old gasket and into the spark plug well
    Eventually it will get so high it will short out the cop or at the least it will throw a misfire
    Very common on cars with 4 cylinder motors
    So common I had a valve cover gasket ready to go when I changed the plugs
    I borescoped my plug wells before removal of plug and sure enough one cylinder had about an inch of oil in it
