Spark Plugs on 2012
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Superleaf444, Aug 5, 2020.
  1. Superleaf444
    Superleaf444 Junior Member
    25
    Hi all,
    I’m a new owner and pretty new to DIY maintenance.
    I managed to clean my hybrid fan after seeing how horribly filthy the cabin air filter was, so I’m looking to the next task.
    it’s a used Prius with 147k miles on it, so I’m going through a laundry list of things to do.
    Long story short, what should the spark plugs be torqued at?!
    Sorry for yet another thread on this, but it seems like the info is pretty chaotic.
    I believe it is 15lbs and 13lbs with anti seize, which is not needed with NGK.
    The video from Nutz about Boltz he says 20lbs, but I’m fairly sure he misspoke. Then in the description it has 13lbs, but he applies anti-seize.
    I s’pose if anti-seize isn’t required I see no point.
    The info is so chaotic, I’m beginning to wonder if this is a thing I should pay to have done, but I’m pretty confident in my ability.
    Also, on one video I watched when they hit 15lbs torque the plugs “clicked”. Any idea is legit?
  2. JC91006
    16,482
    8,399
    Which fan did you clean? The one next to the cabin air filter? Or the HV battery fan?
    15ft lbs, 20ft lbs. I don't think it would matter much. But someone will come and tell you the exact torque (maybe you can even google it)
  3. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    20 Nm or 15 ft-lb, per the service manual
    Mendel Leisk and Superleaf444 like this.
  4. Superleaf444
    25
    HV battery fan. The cabin filter’s grossness made me think it was a good idea
  5. bisco
    49,466
    do you have the service history?
  6. Superleaf444
    25
    I do not. I spoke with the mechanic the previous owner regularly saw and he said he had not changed them. But he gave me an idea of the typical maintenance that was done. It wasn't the most immaculate car in the world, but it also wasn't treated horribly.
    He also thought I should change them, ha.
  7. bisco
    49,466
    sign in at toyota.com/owners and input your vin for dealer maintenance history as well.
  8. Superleaf444
    25
    Thanks, but yeah, she mostly stuck with her local mechanic. So it doesn't show
  9. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  10. Superleaf444
    25
    o_O am I wrong? I mean, I've watched soooo many vids, so I could very well be misremembering. I usually watch them like a handful of times at 1.5x/2x speed weeks before doing work.
  11. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    "o_O am I wrong?"
    You are not wrong; that's just what Grit does here. Best get used to it...
    Superleaf444 likes this.
  12. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    See post #3 and open the attachment. Find the spark plug in the pdf and read the legend. The 3rd value is one of the common torque setting.
  13. Superleaf444
    25
    Awesome, thanks to both of you.
    This is going to be my first spark plug job, so I'm just trying to make 100% certainty that I'm doing it correctly.
    Currently I'm looking to buy 4 NGK 4912 plugs from a local shop, mainly because I see info of counterfeits for Denso plugs, which don't get me wrong could also have the same issue, but I feel like I see NGK issues less?
    Also, probably won't do anti-seize, because of specifications from the above poster and NGK guidance.
    I'm fairly terrified to do this work, so lol. :confused:
  14. ttou68
    ttou68 Active Member
    348
    205
    I don't know how much the local price NGK spark plugs are...
    I bought my from local Toyota dealership online part store and picked up for less than $10 a piece...
    SC16HR11 or 90919-01275
  15. Superleaf444
    25
    The NGK are $10.80 as of today, but it looks like a sale is going on. So whoo!
    I'm currently in a pretty rural location and tbh I've had such bad experiences with the closest dealer, that I'm not trying to go back.
  16. JC91006
    16,482
    8,399
    The cabin filter collects a lot of debris and dust from the outside. I usually change mine out every couple years. The HV fan usually not as bad as it only uses the air from inside the cabin and not the outside of the car. But good job in getting to that fan, it's not a maintenance item I read about people doing often.
  17. bisco
    49,466
    odd that she used the local mech, but he never changed the plugs. i wonderwhat else he didn't do.
    look into egr circuit cleaning when you get a chance
    pjksr02 likes this.
  18. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Most likely not change oil and the filter at times.
  19. Superleaf444
    25
    Yeah, that is on my list. I quickly got an oil changes and all the fluids + air filters. Thankfully, from what I can tell that is covered in the warranty until 150k.
    After talking to the local guy and getting the car checked out by someone else before I purchased it, my suspension is she didn't keep up with maintenance but didn't run it into the ground. Think more of a busy white collar type rather than a teen boy showing off. Got some work done, but not all.
    Also, not many people have worked on Prius models around there, so things def were missed. For instance, the guy that gave me an inspection sticker couldn't even quote me spark plug replacements because he had never worked on a Prius and wasn't sure of the details.
    These are some of the reasons I ended up on this forum and to start doing maintenance myself. (Also, in general poor experiences with mechanics in my past. Good ones are really worth their weight in gold.)
    When I do the spark plugs, I'm going to take off the EGR pipe to get a decent idea of how filthy the rest of the set up is. That procedure, I might end up paying for, because egad.
  20. Superleaf444
    25
    Sorry to keep posting on this thread, but this is going to be the biggest maintenance job I've ever DIY'ed, so I'm just trying to be completely 100% on what I'm getting myself into. I've not used a torque wrench since shop class in high school. Lolz
    Tools needed:
    • Ratchet and the sockets
    • 9/16 or 14mm magnetic spark plug socket (I've seen people complain about short ones not reaching?)
    • Flathead
    • Pliers, I have a Leatherman, so that should work
    • Torque wrench that can do below 20-ft lbs (For some reason I've had trouble locating one)
    • Spark plugs
    • Silicone paste for after putting the plugs in
    Things to note
    • Torque plugs at 15 w/o anti-seize or 13 with anti-seize
    • Gap should be fine but check just in case
    • 9/16 might be slightly loose, but should work. The rubber in the socket should help.
    • Clean near the ignition coils before starting to make sure nothing falls in + make sure to keep track of which one goes where
    • After installing the plugs, before putting everything back, fire up the engine to see if everything is good (PWR mode will force the engine to run. Additionally can do maintenance mode and go around the block.)
    Bonus
    • Can check EGR pipe and valve pretty easily, probably worth cleaning as a small bonus task.
    #20 Superleaf444, Aug 8, 2020
    pjksr02 likes this.
