Spark Plugs Stuck Halfway Out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EmilyH, Nov 28, 2021.
  1. EmilyH
    EmilyH Junior Member
    I was changing the spark plugs on my 2005 prius. It is usually easy/routine but this time the last spark plug wouldn't come out. It felt harder to thread out than usual but once it got halfway out it stopped turning. I have tried spraying it down with wd40 specialist penetrant oil and left it overnight and that had no effect. I bought some deep bolt extractors that will fit over the spark plug but I am not sure that will even help? I don't really want to use a breaker bar and don't know that I even should. Any advice on how to remove it without damaging other things? I was already planning on repairing the threads and using an insert but I can't even remove the spark plug. Lastly, since the plug is now halfway out and stuck there is obviously no way I can start my car to bring it to a shop if I end up not being able to remove it myself?
    Any help/advice is greatly appreciated
    -The other three have been removed with no issues as they have only been in for about 60,000miles
    -Tomorrow will be my third day/attempt at removal
    -They will not turn to tighten or loosen at this point
    - I understand using a breaker bar or any bolt extractors is highly recommended against-I just do not know what else to do
  2. JC91006
    16,827
    8,600
    I would use a long extension/hollow pipe to your wrench (which will give you more torque), try to retighten the spark plug. I would not try and remove that.
    Since this is a 2005, I would leave that spark plug in there until you one day get a misfire code. Then I would think about removing the spark plug. These iridium spark plugs (if that's what you put in there last time), lasts 150k miles or more. So if these are only 60,000 miles old, I would just retighten the plug back in.
  3. ChapmanF
    18,536
    I usually do a back-and-forth, back-and-forth action on those to avoid getting them to a really stuck condition. Since yours got stuck on the way out, it probably will be slightly easier to turn in the in direction from where it is now stuck. Observe I said "slightly easier" but did not say "easy".
    If you can get it to go back in some, you can either put it all the way back in and fuhgeddaboutit as JC suggests, or you could go back to a frequent back-and-forth procedure and see if that gets it eventually the rest of the way out. Working in your favor, some of the penetrating oil you've put in there will be carried into the threads as you turn the thing back inward.
    It can sometimes happen, though, that spark plug hole threads need to be Helicoiled after a bad episode of that. (And of course any chips and shavings then need to all be gotten out of the cylinder.)
    PriusCamper likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    Many of us would of just kept checking the threads are still there by screwing it in a little between each effort of increasing force to get it out. As long as the threads aren't crossed you can use a lot of force with a breaker bar without issue.
  5. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Yikes what a nightmare! Sorry that happened! Please don't spray anything else in there, whatever you use will end up inside the engine when the plug does comes out...not good for it.
    I was taught, years ago, to always remove/replace plugs in an aluminum engine when the car is warm, not hot and not cold. I run them up to operating temp and let them sit for an hour or so until they are warm to the touch and always careful both removing and replacing to avoid the cross-threading nightmare.
    Keep us updated!!
  6. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Might indeed be the cold Minnesota weather factor.
  7. EmilyH
    As it stands, I have successfully replaced the other 3 spark plugs without issue, the (possibly already stripped) spark plug in question is stuck (no budge CW or CCW) and the penetrating oil I used on it eroded the boot of the coil beyond use (I placed the coil back into the hole to keep debris from falling in overnight). Will I be okay to run the engine with one stuck/exposed spark plug? I've read that it can be dangerous to run your engine without all spark plugs and coils properly placed and functioning. My worst fear is doing irreversible damage to my prius so I am approaching each bit of advice with extreme caution. thanks.
  8. Another
    1,819
    517
    Naples, Florida
    Stories like this make me glad that I just go to dealer once every six or eight years to have the plugs changed.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Out of curiosity, has anyone tried using graphite to lubricate the threads of sparkplugs? Normally applied as an alcohol/graphite mixture so it leaves a smooth even layer of graphite as the alcohol evaporates. I've used it on many things, but never thought about trying it on sparkplugs. Read somewhere that Champion used to offer tubes of this as lubricant for people who insisted on using anti-seize.
  10. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Smart! When in doubt get a pro to do it or, at minimum, a mentor who can teach you.
  11. JC91006
    16,827
    8,600
    So what you are trying to accomplish is to re-seat the spark plug. If it won't come out, it shouldn't be that hard to reverse directions and tighten it back in. Your best solution would be to just tighten the plug back into place and drive your car. Don't change that out.
    Here is an image of what you're trying to do with a pipe extension, slip a pipe over the socket wrench, to extend the length and give you a little extra torque to help you turn the spark plug. Just don't use 3 guys to do it.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    No, I would not suggest trying to run the car (for very long) with the spark plug as it is. If you have the ignition coil (semi)installed, the plug would likely overheat because it doesn't have correct contact with the cylinder head- if it fired at all. If you removed the coil then you have a misfire - you could also unplug the injector so you don't melt the catalytic converter, but the hybrid ecu would throw codes due to low engine power ( and might possibly shut down the car?).
    You likely have a condition where a bit of something mucked up threads at the bottom end of the plug. Trying to remove the plug has dragged this bit around and around- galling the aluminum of the head and smearing it into the threads of the plug. Now you have a "lump" of aluminum on the plug that's gouged and mangled the threads in the head.
    Maybe you can idle the engine some to get things warm and try "back and forthing" to get the plug to do something. Maybe the plug comes out- along with most of the threads. Maybe the plug snaps off. Worst case the head has to come off. Maybe heat and some gentle use of an impact gun.
    Last one I had that started to do that- well I tightened it again and it's still running fine over 10 years later (little old lady car with very few miles driven).
  13. pasadena_commut
    pasadena_commut Senior Member
    2,830
    844
    Southern California
    Shortly after we bought our 2007 we had a trusted shop replace all the plugs, which they said was "very difficult". Had I tried it myself I might well have ended up in the same situation as the OP.
    Running the engine with a plug in its current position seems like a bad idea. That cylinder isn't going to run right, might not even fire, and it could burn up the plug or cause it to blow out of the engine. If it were mine I would remove all the plastic and rubber bits around that cylinder and then try warming it up with a heat gun. Slowly. Then try to tighten it back up again with a torque wrench set so that you don't exceed a "safe" amount of torque. That wouldn't be much even if everything was brand new, 12 lb-ft for a 10mm plug or 18 lb-ft for a 12 mm one (I don't recall what size the Prius has). If the plug can be made to go in again without exceeding that "reasonable" torque on the last few turns then it may last a while.
    Otherwise, there would be no shame in having a mechanic remove it and (almost certainly) put in a helicoil to hold the replacement plug. An experienced mechanic has probably been in this situation numerous times and knows how to proceed. Also, already has the tools to do so.
  14. Mendel Leisk
    41,894
    I don't think any of the responders were saying that; you would want to screw the spark plug completely back down and torque.
    Second Gen Repair Manual excerpt, torque spec is 13 ft/lb:
  15. mr_guy_mann
    4,087
    1,997
    NJ-USA
    The OP has "pulled a thread" while trying to remove the one plug. Don't know IF it's possible to go in or out without further damage to the cylinder head or breaking the plug off.
