  1. tylerjames
    tylerjames Junior Member
    26
    north bay
    I am switching my plugs now. I bought this car used and see it has Denso iridiums. I am using NGK iridium.. Will this effect it? Check out the difference
  2. Patrick Wong
    18,200
    6,479
    NGK also is an original equipment supplier to Toyota for the Prius. What is the model number of the NGK iridium spark plugs that you are installing?
  3. tylerjames
    26
    north bay
    IFR5T11
  4. Patrick Wong
    18,200
    6,479
    tylerjames likes this.
  5. tylerjames
    26
    north bay
  6. tylerjames
    26
    north bay
  7. Mendel Leisk
    38,898
    Typically yes. You should be ok.
  8. Patrick Wong
    18,200
    6,479
    The plugs are pre-gapped. The spec is 1.0 - 1.1 mm. I have found that the gap needs to be slightly narrowed to achieve 1.0 mm which is the spacing that I strive for.
