Spark Plus SC16HR11 Dense, is any using it and different??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Aug 28, 2019.
  1. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Currently change all 4 of my original Sc20HR11 to Sc20HR11 on 2013 and apporx 4~5mpg decrease on Highway drive with ECO mode. EV with ECO combination under local drive about same. I was gapped that SC20HR11 at 1.04 ~ 1.05mm and No code or missed fire not noted.
    I have heard Toyota recommend SC16HR11 now and I've a set of 4 plus in hand. Should I try it out or should I back to Old plus. As most Iridium plus can survive 120k miles. My 2013 only has 94K and i'm assuming this old plus can last another 25k miles with slice better mileage.
    SC16HR11 is running hotter, what's it going to do if running hot?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    I am using the revised plugs in mine. No issues.
    Raytheeagle likes this.
  3. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    nothing is going to run hotter, the spark plug is called 'hotter', meaning the self-cleaning takes effect at a lower spark plug temperature /
    mjoo likes this.
  4. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Uh, my experience is with 2-cycle and 4-cycle engines is that “hotter” plugs do run hotter where the arcing takes place at the tips and center electrode. A “too cold” plug would slowly accumulate carbon and ultimately fail when carbon bridged the gap or accumulated to the extent that the high voltage had an easier alternative pathway to ground and did not jump the gap.
    A “too hot” plug would typically have whitish deposits on the ceramic insulator around the center electrode, rather than light brown, and in extreme cases the center electrode would melt or the ceramic insulator would crack into pieces, which would pass out of the exhaust valve if you were lucky , or hang up the valve or crush into the top of the piston if you were unlucky. Further, the tip a “too hot” plug under load could get hot enough to act like a glow plug and cause pre-ignition of the fuel-air mixture before the spark occurred. If you were lucky you would just hear pinging as the mixture ignited essentially too early and you could reduce load in time to prevent damage. If unlucky, full scale detonation occurred where the mixture all ignites at once rather than having a nice, gradual flame front, and that would over-stress combustion chamber components both with heat and the shock of the explosions, resulting in burned valves, holes blown in piston crowns, and possibly cylinder scoring. Correct heat range depends in part on the loads you create with your style of driving, so I would check how your old plugs looked upon removal and select either hotter or colder plugs based on that evidence.
    Zeppo Shanski and mjoo like this.
  5. Tekken
    Tekken Member
    257
    77
    They all looking similar burned.. but was not drive by me. I have been drive like a grandma since bought this prius
  6. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    More proof that the 2ZR-FXE generates more carbon than Toyota designed for?
    Pixel XL ?
  7. Robert Holt
    1,313
    888
    Not sure, mjoo, as carbon accumulation seems to depend on the extent of richness of the air-fuel mixture, the anti-deposit additives in the fuel mix (even Top Tier fuels differ in amount, types, and effectiveness of additives), combustion chamber temperatures, and extent of oil blow-by once the engine has significant ring or sidewall wear, or just stuck rings, and amount of the typical duty cycle the ICE and specifically the combustion chamber spends at low temps, I think.
  8. Robert Holt
    1,313
    888
  9. Robert Holt
    1,313
    888
  10. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Well, I guess 3 posts beats my meager 1 post...
    RMB likes this.
  11. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    RMB likes this.
