Speaker blown
Discussion in 'Gen 3 Prius Audio and Electronics' started by 4rpr15, Jan 1, 2016.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Has anyone noticed that the stock speakers are very susceptible to getting blown? Rarely do I have crank up the music as I'm driving, but the right front speaker is rattling so bad now that I don't even turn on any music now until I can take it in to get replaced. The speaker settings are all slightly over mid range for bass, treble, etc....
    iPhone ?
  2. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Drill it out and replace with some JL or JBL speakers. The 3-way and 2-way are good.
  3. 4rpr15
    1,056
    375
    WI
    That's what I was thinking. Easy to replace myself or is there a lot involved? I have a feeling these will keep blowing.
    iPhone ?
    49,509
    i haven't, but it doesn't surprise me. it's a pretty cheesy system. is it the base, or does persona get an upgrade?
  5. 4rpr15
    1,056
    375
    WI
    I believe that it's base.
    iPhone ?
  6. apt5020
    881
    1,294
    Prius City, CA
    Very easy. Drill it out. Get some rust proof screws and washers to mount. Buy it from crutch field since they give you the mounting brackets and speakers adapter. Hope that help
  7. 4rpr15
    1,056
    375
    WI
    I'll have to check reviews on speakers. This includes removing the door panel correct? Should I replace all 6 speakers?
    iPhone ?
  8. apt5020
    881
    1,294
    Prius City, CA
    Tweeters kinda hard. I did not replace my. The other four I did. Since everything is out. Add door insulation
  9. BZzap!
    BZzap! Senior Member
    1,607
    877
    Those speakers are the epitome of cheap. They are all plastic junk. Definitely replace them with some good after market units. The money that you spend on one of these factory speakers ($140 apiece) is a crazy.
  10. 4rpr15
    1,056
    375
    WI
    I agree. I just need speaker replacements without an amp or anything. Nothing too major, but definitely a better upgrade is needed.
    iPhone ?
  11. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    ...and the base system speakers are 4 ohm, not 2 ohm like the "also crappy" JBL systems.
    Lucifer likes this.
  12. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    I bought some 4-ohm Rockford Foscate 2-way 6x9 from crutchfield for $40. It was a big improvement over the crappy stocks
  13. 4rpr15
    1,056
    375
    WI
    Self install them, how hard was it if you did? I just don't like the idea of opening door panels and will probably have someone do it for me.
    iPhone ?
  14. Imaginex20
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    I
    I did it myself. Very easy just need a drill with 1/8" bit. You'll also need 8 additional screws to screw in the bracket to the door.
    The door panels on the car are so easy to take off. Two screws and they pop off. Also the door handle pops off the panel, don't try to remove the cable mechanism
  15. 4rpr15
    1,056
    375
    WI
    Did you replace all but the top dashboard speakers?
    iPhone ?
  16. Imaginex20
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Only the front 6x9's
  17. 4rpr15
    1,056
    375
    WI
    Why didn't you replace all 4?
    iPhone ?
  18. Imaginex20
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Because I don't care for how the back sounds. I wanted a better front sound stage. Audiophiles (not saying I'm one) don't like rear speakers either
  19. 4rpr15
    1,056
    375
    WI
    Do you plan on anything else like an amp addition down the line?
    iPhone ?
  20. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    I just replaced the fronts and the imaging to too far forward now.
    iPhone ?
