Speaker Replacement in 2013 Prius 2
Discussion in 'Gen 3 Prius Audio and Electronics' started by PRE-US Blizzard, May 12, 2013.
  1. PRE-US Blizzard
    PRE-US Blizzard New Member
    I have a couple of questions regarding speaker replacement for my front speakers. I have a set of Polk DB Components that I am going to install BUT did not know if I should remove the front squawker and replace it with the tweeter or make a bracket and put the tweeter with the woofer in the traditional location. Please advise of any experience in this area. I have installed many systems before and just planning this one out before attacking it. THANKS!
  2. Cheesehead
    Cheesehead Junior Member
    28
    Unless you have some way to time align the tweeter in the dash with the mid in the door you will have some delay in sound from the mids reaching your ears compared to the tweets. But in the Prius it might be minimized due to the extended dash. Measure the distance from dash speakers to driver ears and mids to driver ears and see how much difference there is. If not much difference you probably won't be able to distinguish any problems. Just my $.02!
  3. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    Are there any speakers that are a drop in replacement for the factory speakers? I don't want to do any cutting, etc.
    iPad ? HD
  4. BillyBuerger
    BillyBuerger Junior Member
    26
    I
    I don't believe so. The speakers are a custom 6x9 but slightly larger and without the standard mounting pattern. There are adapters that you can get that are relatively cheap that will make it easy to swap. I know Crutchfield has them.
