Speakers revisited...
Discussion in 'Gen 2 Prius Audio and Electronics' started by motty99, Nov 20, 2006.
  1. motty99
    motty99 New Member
    28
    I tried a pair of 4 ohm speakers (which shall remain nameless) and was very disappointed by the bass response and loss of power...so, I investigated and found that JBL makes a component set that is 2 ohms (JBL GTO607C)...let me say that I believe these are the way to go...the tweeters clear the shrillness of the old, and I finally have some low end (though there is still that bump in the upper bass) that I can live with...also Dynamatted the doors...
    Recommended...
  2. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Did you use the crossovers that came with the kit or just the speakers? It looks like a nice set. I presume you replaced the fronts only, or did you replace the backs too?
  3. motty99
    motty99 New Member
    28
    <div class='quotetop'>QUOTE(jbarnhart @ Nov 20 2006, 01:04 PM) [snapback]352153[/snapback]</div>
    Did not use the crossovers...since the front tweeter and woofer are already split at the amp...but I will use them when I do the back doors!...:D
