Speaking of fuel for the Military...
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Keiichi, Feb 27, 2012.
  1. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Cool, but honestly I'm not sure I see how much advantage there is to a hybrid tank, but who knows, it'll be interesting to see the technical details.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That's not a tank, the main weapon is only a 25mm. It's an infantry fighting vehicle and carries 12 men. Ii looks like a streatched version of the M2/M3 Bradley Fighting Vehicle which was built by the US company that BAE bought. It is a lot heavier than the Bradley, almost twice as heavy, that would primarily be for more armor.
    Close combat vehicles (Tanks, IFVs) spend a lot of time in "Silent watch". A hybrid battery pack would be good for that. They would be able to keep critical systems up for hours without running an engine. It would also be advantageous to be able to move short (meters to km distances) without firing up an engine.
    austingreen likes this.
  4. austingreen
    austingreen Senior Member
    13,667
    4,209
    Austin, TX, USA
    Seems like major advantages. The big question is how well the batteries do sitting around in the heat.
    I found this strange statement in the article
    Which seems crazy to think anyone would want to have to supply the recharge in combat. PHEV fighting vehicles seem like a big advance, BEV transports and tanks don't make much sense when fighting a war.
    http://green.autoblog.com/2012/02/27/hybrid-army-tank-renderings-some-specs-revealed/
    emphasis mine.
  5. Keiichi
    808
    79
    Goleta
    The advantage of a hybrid tank would be as xs650 stated... Urban warfare, tanks make a hell of a lot of noise because of the engine. Also, its thermal signature due to the engine tends to make it noticeable.
    Another thing to consider is that in order to fight a war, there is always going to the issue of supply lines. A tank (Even one that doesn't look like a traditional main battle tank) will still need a means to move that hunk of mass, which would be fuel. The thing is, tanks are damn heavy with the armor and armaments on it and even with a fuel efficient turbine engine to drive it, the fuel requirements are pretty hefty and in some environments, require serious air filtering in order to run effectively well.
    A hybrid option would allow a tank to be a little bit longer range in mobilization, and in some cases, as cited above, a bit 'quieter' in close combat situations.
  6. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    The low end torque is very valuable when performing the "Get the Hell out of there" combat maneuver.
  7. Former Member 68813
    3,524
    983
    US
  8. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    I could see tank drones: smaller, faster, less fuel consumption than the current proposed hybrid tank.
    DBCassidy
  9. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    As xs pointed out it's an armored infantry vehicle, not a battle tank. I'd think that the problem with tank drones is communications. Might as well put a guy inside it. They could become more flexible, with optional remote control, but I suspect that instead you'll simply see decreased use of tanks and a shift to other weapons tech.
  10. Former Member 68813
    3,524
    983
    US
    What's next, remote controlled individual solders?
  11. dbcassidy
    1,581
    290
    Yep, anything is possible with the current technology.
    Maybe, there will be a Skynet equivalent with cyborgs doing the fighting for humans.
    DBCassidy
  12. bwilson4web
    16,143
    Air and oceans are relatively benign and uniform compared to surface conditions. One good mud bog is a technological challenge of the first order. Then there are ditches, trees, and friendly bipedal critters all over the area.
    Now the Marines are using the "R-gator" and though still a little large, it makes a lot of sense:
    John Deere R-Gatorâ„¢ Military Utility Vehicles JohnDeere.com
  13. dbcassidy
    1,581
    290
  14. bwilson4web
    16,143
    Search for "marine mule" and you can find images of:
    But in reality, the best use is to carry all the 'crap' we are supposed to carry . . . worse today!
    The one I'm thinking of showed a photo of a marine with a remote-control walking along with the mule. There might have been one where the marine walks along and the mule follows. But that reminds me of an old joke . . .
  15. dbcassidy
    1,581
    290
    Yep, that was a basic of a platform as it could get!
    DBCassidy
  16. bwilson4web
    16,143
    Well this one would make the daily commute more fun:
    Road rage on steroids.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    106mm (actually 105mm) Recoilless?
  18. bwilson4web
    16,143
    Yes with the 50 cal spotter on top. When I went through infantry training school, the instructor said that based upon the spotter round 'in flight' a good gunner would fire the 106 before it hit.
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
  20. dbcassidy
    1,581
    290
    LOL, THAT would take care of the tailgaters!
    DBCassidy
