Special head screw
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mina Botrous, Feb 15, 2023.
  1. Mina Botrous
    Mina Botrous Junior Member
    24
    new zealand
    Hi all,
    Last week we purchased a Gen 3 Prius and yesterday I was replacing the head unit to find that two of the screw has these 2023-02-15 012.JPG special head screws - I assume as an anti-theft, any idea what is this called or how to take it out?
    Thanks
    Mina
  2. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    Some tool stores sell a collection of anti-theft bolt remover attachments for most every type... But I've never seen that shape. Maybe you could zoom out and show what part of the dash this is? My first impression is you can work around it, but would need more picture to be certain.
    If all else fails mark the center with an automatic center punch and drill the head off.
  3. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    Hi Mina,
    Cut a slot down the center with a Dremel and remove it with a regular flat head screwdriver, or use an angle grinder to grind down two sides so you can use a spanner to turn it.
  4. Mina Botrous
    24
    new zealand
    this is holding the head unit - I think as anti theft.
  5. Mina Botrous
    24
    new zealand
    I tried that also with my Dremel but it is in an awkward tight position, I'm leaving the drilling as a last option.
  6. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Have you tried a universal socket?
    The spring-loaded pins push into any recess they find in the screw head, and they don't care about shape or symmetry.
    Mendel Leisk and PriusCamper like this.
  7. PriusCamper
    12,048
    4,892
    I tried one of these when I guy I was installing a pack for had one. Was impressed with its durability... But I'd probably break it sooner than later...
    For this specific challenge I suspect it might work if it's wide enough in diameter, but likely not that wide.
  8. Mina Botrous
    24
    new zealand
    this is a good idea, I will look for it in bunnings and see how it goes.
    thanks mate :)
