Specify a desired route to the navigation
Discussion in 'Gen 3 Prius Audio and Electronics' started by lex, Feb 12, 2024.
Tags:
  1. lex
    lex 2010 trim level V Prius & a 2005, always garaged
    93
    Fresno
    Is it possible to specify a desired route to the navigation, taking what may not be its default or most common route, i.e. opting for a less commonly used freeway between points?
    2010 Gen. 3 Prius (trim level V) navigation
  2. ChapmanF
    15,464
    I usually do this by adding one or more intermediate "destinations" that happen to be along the route I want to take. An easy way to do that is to add a destination by picking it on the map, somewhere on the desired road.
    When you do that, of course, your distance-to-go and ETA are showing just to that next intermediate "destination" by default, though you can press that distance/ETA icon to expand it to show the whole sequence of distances/ETAs.
