Speed Limit options
Discussion in 'Prime Main Forum (2017-2022)' started by xray22, Jun 26, 2017.
  1. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    In the manual section "meter customize" options, Under Speed Limit it lists
    1) Off
    2) Only Display
    3) Caution
    Does anyone know what they mean by "Caution"?
    Also is there a way to keep the posted speed limit post visible all the time while still seeing miles and time on the navigation screen?
    Thanks.
    51,140
    probably an audible or visual warning if you're exceeding it, but not positive.
  3. xray22
    31
    Vanouver, WA
    I was looking for that but didn't see or hear anything when set to Caution. Must be something else?
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    I fiddled with them. As far as I can tell, none of them do anything. I get the HUD popup no matter what the setting. I submitted it as a bug.
  5. illumiN8i
    illumiN8i Active Member
    184
    141
    Grand Rapids, MI
    2018 Prius Prime
    The speed limit settings control the speed limit sign on the compass display. I believe speed limit needs to be enabled in the navigation system options first.
    See the attached picture. Off removes the sign. Only display shows the sign. Caution displays the orange border when driving faster than the limit.
    Morrisdb, java007md and benagi like this.
  6. illumiN8i
    184
    141
    Grand Rapids, MI
    2018 Prius Prime
    You can disable speed limit on the HUD pop up by turning speed limit off completely in the navigation system options.
    I'm beta testing an upcoming version of the Carista OBD2 customization app that allows you to disable speed limit pop ups on the HUD only without disabling it on the nav system.
    Nic Steussy likes this.
  7. xray22
    31
    Vanouver, WA
    Thanks for replying after more than a year. Now I understand what caution does. My problem was that I never you the "compass screen" so didn't notice the orange border. Too bad it doesn't show up on a screen I use or the large display.
  8. illumiN8i
    184
    141
    Grand Rapids, MI
    2018 Prius Prime
    Haha, yeah I found this old thread while searching to figure this out myself. The manual is misleading. I figured I'd post the correct answer to help others searching for the same thing.
    walterm likes this.
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Also keep in mind that the speed limit signs are what's in the mapping of the nav system. If the mapping is out of date or incorrect, you'll be shown an incorrect speed limit.
