Speed sensor connector
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ilya980, Mar 2, 2025.
  1. ilya980
    ilya980 Junior Member
    74
    Massachusetts, USA
    How do I unlock the right front ABS sensor connector on a 2013 Prius C one? Does anyone have a photo of the connector, or can tell me how it unlocks?
    Thanks.
  2. Leadfoot J. McCoalroller
    8,088
    7,568
    Pennsylvania
    2018 Prius c
    I haven't done a front, so I'll apologize now if this doesn't help.
    When I did the rear bearing on mine, the sensor strain relief was a little plastic clip that folded over itself to form a clamp that fit into a hole stamped in the backing plate.
    Once you undo the clasp and "split" the strain relief collar, it would pop off entirely and you could then manipulate the wires to access the actual electrical connector. That one was a fairly obvious quick-disconnect.
    Good luck!
