Speedo Calibration
Discussion in 'Gen 2 Prius Main Forum' started by ibis315, Jan 5, 2006.
  1. ibis315
    ibis315 New Member
    San Jose, CA
    I was wondering if the speedometer can be calibrated either with hidden menu or with scan tool at the dealer. Old cars in the past with analog gauges had fixed ratio gear from the wheel connected to the speedo, so to recalibrating the speedo after changing the wheel size was a pain. I'm asking this since the Prius is packed with software for controlling most things, I was wondering if I can calibrate the speedo if I change my wheels to something other than 185/65/15. Anyone looked into this or want to poke around?
  2. KTPhil
    KTPhil Active Member
    1,379
    I don't think so. The Nav system can be calibrated (Menu | Setup | Calibration ) but I don't know whether this affects the MPG display.
  3. Denny_A
    Denny_A New Member
    133
    Fox Valley, WI
    Also don't think so, but...if you have a GPS with speed readout, the change can be fairly closely estimated.
    I have a PDA style portable GPS. My 2000 Toyo 4Rnr was about 2mph fast at 60 mph indicated. So it was about 3.3% off on the high side. My '05 PRI is 1 mph fast (same GPS) at 60 mph. So the PRI is a bit less than 2% high. My '88 Honda accord was indicated faster by 4%. When I changed to larger tires the readout was right on the money (as measured on a 20 mile calibrated course on a local highway). So, for the '88 Accord, a 1040 mile trip, by odometer, was only 1000 miles actual.
    If a GPS is used, and as accurate a solution (i.e., 3D) as possible is received by the unit, it should give a fairly accurate estimate of speedo error.
  4. bookrats
    bookrats New Member
    2,843
    Seattle, WA
