Speedometer calibration available yet?
Discussion in 'Prime Main Forum (2017-2022)' started by EdTechGuy, Oct 9, 2020.
  1. EdTechGuy
    EdTechGuy New Member
    Missouri
    2020 Prius Prime
    My 2020 Prius Prime with less than 4000 miles on it has a speedometer that displays 2 mph over the actual speed, at highway speed. This is verified by the timing between mile markers (60 seconds at 62mph displayed) and Google Maps GPS (60 mph reported at 62 mph displayed). Can Toyota (or me) do anything to calibrate this?
    I admit my 2011 Prius had the same problem, but I just chalked it up to tire wear. Other forum threads have raised this question too. I learned to live with it, but wondered whether anything had changed since then?
    Corrected: "over" the actual speed limit, not under. Thanks for the feedback!
    #1 EdTechGuy, Oct 9, 2020
  2. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    I thought manufacture do this on purpose maybe to keep the real speed down? Get larger tires to compensate for the discrepancy. It is also a known fact that the mpg display on Prius (without any EV mode in case of PP) is off by ~7%.
    Edit: Oh, wait... you are saying your speedometer is already reading slower than actual speed. That is unusual, isn't it? I thought they always read faster than the actual speed. Hmm, then you have to put smaller tires to compensate for the discrepancy. That may also increase the actual mpg to compensate for the mpg discrepancy. lol
    #2 Salamander_King, Oct 9, 2020
    49,396
    yep, no updates coming, ever
    been going on forever
    not gonna happen
    #3 bisco, Oct 9, 2020
    Tips likes this.
  4. ChapmanF
    15,477
    in fact it's happening right now
  5. bisco
    49,396
    as we type
  6. fuzzy1
    10,164
    Don't you mean the speedometer is reading high, not low?
    Sorry, but this is standard industry practice here and nearly worldwide, driven in part by laws in some areas that forbid under reading, in a world where the old mechanical speedometers had a significant error spread. Back then, the meters had to be biased high in order to meet the laws. Now it is a very long-standing standard practice.
    And this is explained in many other forum threads.
    So, no, Toyota is not going to fix it. You can address it by changing tire diameter, or by installing an OBDII-port engine monitor (ScanGauge-II, or smartphone Torque app, or many other products) that will read and display the internal speed being used by the computers, which has far less error.
    EdTechGuy and Mendel Leisk like this.
  7. ChapmanF
    15,477
    it wasn't so long ago
  8. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    The OP is confusing.
  9. Mendel Leisk
    38,652
    First sentence by OP currently says his speedo is reading high. Which is as it should be, and really: if this sorta thing keeps you awake at night, you've got bigger issues.
    Switching to bigger tires to "remedy" is a fool's mission.
    #9 Mendel Leisk, Oct 10, 2020
  10. Mark57
    2,945
    2,736
    OK
    You're not supposed to type and drive, while high . . . :eek:
  11. ChapmanF
    15,477
    while we're singing
  12. bisco
    49,396
    expectorating covid
  13. ChapmanF
    15,477
    that is so not in the song
  14. Tips
    Tips Member
    128
    65
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Mark57 likes this.
  15. Jusmadam
    Jusmadam New Member
    Indiana
    Three Touring
    I doubt Toyota will ever fix this problem. With the speedometer programmed the way it is currently, Toyota avoids any possible litigation involving the speedometer from ever reading higher than your actual speed. SO... The best solution I see is changing your tire sizing. I have tire size 195/55R16. I notice the difference in actual vs. speedometer reading the most at 70 mpg, with my gps reading 72 mph. That is roughly a 3.1% difference between the two. Don't quote me on this, but I read somewhere that North American speedometers have to be within 3-4% of actual. Now if you use this handy website I found for calculations: tacomaworld com / tirecalc. sorry about the spacing, but I couldn't post the link.
    This will give you a good idea how different tire sizes will help negate the difference between actual vs. speedometer readings. The calculator gives you several different value comparisons between two different tire sizes, most importantly the speedometer difference.
    For example with my tire size: 195/55R16 3.1% difference roughly
    Tire size 195/60R16 would reduce the difference by ~ 3.14%
    Tire size 195/65R15 would reduce the difference by ~ 2.2%
    Looks like the 195/60R16 would roughly negate the difference from the actual vs speedometer reading.
    Keep in mind these are ROUGH estimates and I don't know how sensitive the speedometer is when changing between each mph or any gps for that matter. I am also not sure if this ratio holds true for all speeds. I think it would be wise to come as close as possible to reducing the differences, but avoid going over the difference.
  16. Mendel Leisk
    38,652
    How is it a problem, if speedo reads slightly high?
    Changing tire OD’s introduces much more significant “problems”: throws odo off, and a larger OD will (obviously) raise the car, reducing mpg, reduce cornering stability. If you’re ever selling the car most buyers will not be impressed. A lot of tire places (Costco for one) will refuse to install non-stock tire sizes.
    FWIW, this “problem” is mandated by various levels of government, in an attempt to slow people down a bit.
    #16 Mendel Leisk, Oct 18, 2023
  17. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    The factory display reads high by at least 3.17% based on the ecu values with factory tires. The worse thing is you end up driving slower than the speedometer indicates, which often upsets Ram trucks behind you.
    I use a $30 obd2 display primarily for coolant temp but secondarily to read actual speed.
    A feature I like is the coolant temp alarm which can be set lower than factory. I also have a “not to exceed” highway speed alarm to avoid tickets with no remediation options.
    #17 rjparker, Oct 18, 2023
  18. sylvaing
    sylvaing Active Member
    1,028
    425
    Speedometer only or also odometer? Having a 3.3% error in odometer means the battery warranty terminates over 5000 km too soon.
  19. rjparker
    7,918
    4,680
    Texas Hill Country
    Just the dash speedo
    sylvaing likes this.
  20. Mendel Leisk
    38,652
    Yeah the only outlier is the speedo, by design. Too, if speed limit is for example 50 mph, and you absolutely must not fall below that, go 52~53 mph? A lot less involved.
