Speedometer shows 0mph (odometer not going up, trip A & B not going up, no cruise)
Discussion in 'Gen 2 Prius Technical Discussion' started by andy song, Nov 20, 2020.
  1. andy song
    andy song Junior Member
    Title pretty much says it all
    Just bought a 2007 prius and it runs and drives fine
    Yesterday I get in the car and head out and tried to set the cruise control and it won't set. Then k realized my speed is 0
    Odometer not going up
    Trip A & B not going up
    Everything else is normal
    Any ideas?
    SFO likes this.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,475
    1,584
    NJ-USA
    I would suggest you get a mini vci cable with a copy of techstream software and set it up on an old windows laptop. That way you can scan all of the computer modules on the car to check for fault codes that could point you in the correct direction.
    I don't recall the specifics on the prius but typically something like the ABS or transmission module will take readins from a sensor and process that into a Vehicle Speed Sensor signal and send that info out over the data network. Other modules like the engine computer or the Combination Meter (CM or "speedo") will read and use that data.
    So you need to see if the problem is that somehing isn't creating the VSS data or signal, OR if the CM can't talk to the network.
  3. mehranali012
    mehranali012 Junior Member
    US
    What dashboard show any error message
    SAMSUNG-SM-G928A ?
