Speedometer way off. Failure problem help
Discussion in 'Gen 2 Prius Technical Discussion' started by Rjhdog, Dec 22, 2011.
  1. Rjhdog
    Rjhdog Junior Member
    Ca
    Hello all,
    I know of the slight 4%-10% mph difference commonly discussed here but this morning I noticed a huge discrepency. Speedometer showing 115 mph when Traveling 65 -70 mph on highway. Also showing 50mph while going 30 or so.
    Tire size is stock.
    Just noticed it today.
    Its an 04 Prius with approx 130k miles.
    Questions:
    Is it safe to drive it or is this a sign of a larger failure to come?
    Is it a DIY fix?
    Figured at least to disconnect battery to see if it helps, good idea?
    Any advice appreciated.
    Many thanks. RJ
  2. fuzzy1
    10,165
    Did you accidentally hit the button that converts the display to kilometers per hour?
  3. saechaka
    saechaka Member
    225
    On most Pri it's about 2mph off. What's the formula to convert from mph to km?
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    1.6 conversion so 1 mile equals 1.6 km. 70mph is approx 113kmph so yup that 115 figure you saw was most likely kmph. 30mph=48kmph
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep, definitely km/h.
    50 km/hr = 31 MPH
    115 km/h = 71 MPH
  6. Pinksand
    Pinksand New Member
    Los Angeles
    OH, that is probably what I did yesterday when I washed the car. How do I turn it back to MPH instead of KPH? I am not in front of my dash, where is the button located to turn it back to MPH???
    Thx!
  7. jdenenberg
    jdenenberg EE Professor
    3,852
    1,844
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I remember the button being at the bottom right of the MFD.
    JeffD
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Look near the hazard light button.
