Splash Guards
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Fred Wacksman, May 26, 2008.
  1. Fred Wacksman
    Fred Wacksman New Member
    91
    Mason,Ohio
    Before I start installing my slash guards, I wanted to know if someone can give me a heads-up. I bought mine from Prius Chat Shop and they come with decent directions, but I wanted to know if there are any suggestions for taking out the pop in plugs. Also, if there are any additional heads up for the job. I'm planning on just turning my wheels for the front and jacking up the car with a floor jack for the rears.
    I have read the threads on the subject, but looking for more guidance. I do intend to use a fourth screw to hold down the flap tip.
    Thanks,
    Fred:)
  2. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    you'll need to remove the rear wheels if memory serves, other than that it was simple
  3. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    Here is the best installation instruction I've seen here. It has many photographs and explains most everything. I used these instructions and installed mine in less than an hour. Good luck!! Molded Splashguard Installation
  4. problemchild
    problemchild New Member
    429
    36
    The parts for the front and back are different. Im talking about the mounting parts that hold the flaps. Make sure you pay attention to which is what.
  5. Fred Wacksman
    91
    Mason,Ohio
    Wow, it doesn't get much better than this !!!
    Thanks a lot,
    Fred
  6. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Put some wood under the front of the front tires to act as a wheel block, unless you are on a rearward slant, then put them under the back of the front tires.
    I just installed a clearshield in my garage and am just now getting ready to tackle the mud guards.
    I may post some clearshield pics later.
    ZC1
  7. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    sooooooo much easier if you remove the rear wheels..
