splash shield under front end...is it necessary?
Discussion in 'Gen 2 Prius Main Forum' started by gene4655, Jul 18, 2011.
  1. gene4655
    gene4655 Junior Member
    51
    Had to pull loose the black plastic like splash shield under front of '06 Prius,as repeated encounters with curbs had loosened it. My question is, is the thing essential? Car doesn't seem to know it's not there but does ithurt to go without it? Thanks for advice.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it's designed to create drag. without it, you will probably feel wind pushing the car around more. it might also have a very very small mpg effect.
    essential... i don't think so...
    I'm not looking at it as i type, so i'm not sure how it's held on, or if it might be covering a seam in the front end. if it comes off and it's not too irritating while driving, leave it off.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    No its not neccessary at all if you don't mind rocks, mud, and other road debris kicking up into very very expensive and not very tough AC Condenser clogging it and generally just beating the crap out of it.
  4. a_gray_prius
    2,927
    782
    IL
    It probably smooths out the airflow underneath the car - this contributes to improvements in MPG due to the aero of the car. I wouldn't take it off. In fact, I would buy one to cover the entire bottom of the car so it's flat (if it were available).
  5. gene4655
    51
    Hey, Ed, thanks for a level headed reply. You do sarcasm well (as I'll bet your wife says, too!)
  6. danl
    danl New Member
    231
    Boston, MA
    It is very necessary, imo. Just this past weekend, I had to help my brother-in-law replace a steering fluid pipe ($150) on his Saab because he had a hole in his splash shield and a rock made it through and nicked the pipe.
  7. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    ive had mine off for probably 150k miles at least.I dont think it made a difference in handling or mpg. I wouldnt take it off just because, but if its broken where its hanging down, id remove it.
  8. Agape
    Agape Member
    378
    Ireland/Eire
    I will put it plain:
    This works in reverse to ''remove Pampers from baby's nice person''. Result is obvious.
    :eek:
  9. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    I'd replace it. On another car, I removed the splash shield (same reason as you) and it altered the aerodynamics enough that the car would overheat on long drives. Replaced the splash shield and Voila! - no more overheating.
    Kal Of The Rathi likes this.
  10. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    With my old car the guys at the oil change place took mine off as it had been beaten to hell and while they noted it on the receipt they did not tell me. A few months later I started having AC issues while stopped - a fan had stopped working, likely hit by a stone or other road debris.
  11. gene4655
    51
    Many thanks to all for the reasoned replies. I guess I'll bite the bullet and pay what my Toyota service center thinks they have to have to replace it. Again, thanks.
