Splicing Headlight Wiring Connector Issues
Discussion in 'Prius v Main Forum' started by Gahzoo, Oct 27, 2025 at 9:27 PM.
  1. Gahzoo
    Gahzoo Junior Member
    2012 Prius V wagon. 354k
    - Replaced passenger side headlight bulb with 100w H11 generic from Amazon.
    - Bulb soon failed with evidence of burning around base, as well as "welding" itself to connector.
    - Mechanic had to replace connector by splicing and crimping into existing wiring harness.
    - Car now will occasionally throw a bunch of lights on dash. Scan for code, no code stored. Clear code anyways to turn off extra lights on dash.
    - Car will also now turn off ECO mode, which I always leave on.
    In short, I know my car and how it normally operates. Is it reasonable to conclude given the electrical systems in a Prius V, that any electrical modification will cause all kinds of potential related chaos? I'm guessing, yes!
    - Had a similar issue recently with spliced wires for an aftermarket fan. What a nightmare. Issue solved when replaced with OEM.
    - In other words, these cars are highly sensitive to splicing of wires. I'm convinced that my only solution is to replace entire headlight wiring harness with the OEM part. Thought/opinions are welcomed. Thank you!
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,979
    6,172
    Texas Hill Country
    If you have aftermarket LED bulbs in those sockets they can cause interference.
  3. Gahzoo
    Never had that issue before, however from now on anything electrical for my Prius will be OEM, ONLY!
  4. rjparker
    9,979
    6,172
    Texas Hill Country
    There are led bulbs with built in filters and there are plug in filters as well. The splices on those circuits (eg non-comm) are not the issue.
  5. Gahzoo
    Ok, thank you.
    Gonna' try just replacing the bulb with OEM, first. Fingers crossed!
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,424
    2,393
    Taylors, SC
    I would examine the mechanics work first.
    The wires are of a very small gauge.
    If he or she used crimped connectors the connector may have high resistance and causes a fault and a voltage drop.
    In this case, solder connections covered with heat shrink tubing is a much better long lasting option.
    Gahzoo likes this.
  7. Gahzoo
    Good suggestion. Ty
  8. Air_Boss
    Air_Boss Senior Member
    4,174
    1,170
    New Yawk
    A 100w halogen lamp capsule could easily melt the lamp holder base if not also the wiring, especially if corrosion was present.
    Gahzoo likes this.
