Spot for Scangauge?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Azimuth, Jun 30, 2009.
  1. Azimuth
    Azimuth Member
    136
    32
    Austin
    has anyone discovered a good place/way to mount a scangauge II in their Prius gen3?
  2. fuzzy1
    10,167
    So far mine is velcroed to the top of the stalk housing behind the steering wheel. Make sure the telescoping wheel is pushed in all the way first, insuring the velcro goes on the portion that is always exposed.
    Blendmount, mentioned in one, two, three previous threads (and a few more) looks promising, but I haven't sprung for it yet.
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    The sticky side of velcro will never touch any part of my vehicles. It can be a pain to remove and even damage what it was stuck to.
  4. cthindi
    cthindi Member
    177
    85
    Connecticut
    Fits perfectly in the small box below the cd player with extra cable tucked behind. No velcro or any other permanent fitting. Can be removed any time and i can use scanguage buttons as well.
  5. fuzzy1
    10,167
    That small box in your 2005 must match the one on my older Subaru, and it is a great ScanGauge location. I had to bore a hole in the back of the box so the cable could pass behind the dash, and add a bit of nonslip rubber mat for a friction fit.
    But the 2010 P-II has no such box.
  6. Rest
    Rest Active Member
    1,210
    53
    CA
    We are talking about the 2010 Prius right? No small box below the CD player.
  7. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    well, not the best but ok. i used double sided tape and put right under where drive would be on shifter, its at an angle but works well, i accidentally found a great location for my garmin 150. that is in in the pocket of the drink holder closest to shifter, it nestles in and works as well as being easy for me to see
    fred from nashville
  8. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    I got the left A-pillar mount from pro-clip. The nicest bracket I've seen from them.
    ProClip Mounting System - Device Holders and Dashboard Vehicle Mounts
    I bent a piece of aluminum to cradle the SG from behind and screwed that to the proclip, and ran the cable from the back jack on the SG, down behind the trim along the front of the door (to the side of the dash. No velcro for me...the heat makes the glue too soft and it fails. It's a nice clean solution and in a good location for the peripheral vision. I can post some photos if you'd like.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Velcroed to the steering column cover, between the steering wheel and the dash board. Easy to take a quick glance at it. I use the connector on the back, cable is tucked out of sight,
  10. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    Shots of my setup
    6 people like this.
  11. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    It looks great! how did you snake the wires? I am now thinking about getting one and putting it there.
  12. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    nice job nyty-nyt
    Looks like it was made for that spot, and the cable routing looks good too.
  13. thegreatll
    thegreatll New Member
    oviedo
    nice setup, and the cabling is great
  14. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    Pardon my ignorance, but what exactly does the scanguage do?
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  16. jashall
    jashall Junior Member
    Vancouver, WA
    I sent an e-mail to proclipusa to see if they'll make a Scanguage II device mount to attach to the "Toyota Prius 2010-2011 - ProClip Left Mount." From nyty-nyt's pics, that is exactly what I need. Anyone else interested should do the same so they'll know there is interest.
  17. jashall
    Vancouver, WA
    ProClip CustomerService to me
    show details 6:45 AM (4 hours ago)
    We are sorry to say that we will not be making a holder for the ScanGauge II.
    Due to an overwhelming request, worldwide, to develop all different kinds of holders/mounts, we must prioritize.
    We are very sorry for the inconvenience and hope that we can provide mounting solutions, in the future, for your other devices.
    Best Regards,
    ProClip USA Customer Service
    Toll free: +1 800-296-3212
    Email: [email protected]
  18. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    I bought the left pillar mount for my SG. I just bought the center console clip for my Droid 2 while I was on the proclip site. I was looking for a good place to put the phone (it does not fit in the tray under the armrest and it is pain to get to if needed. I use the holder from the stock belt clip and just bolt it to the mount.
    Thanks for the link to proclip!
