Spotted: 2008 Toyota Prius!
Discussion in 'Gen 2 Prius Main Forum' started by Tideland Prius, Jul 30, 2006.
  1. Tideland Prius
    16,445
    http://thehollywoodextra.blogspot.com/2006...g.html#comments
    ok, I realise some people have a beef with this site and it's accuracy. Some have noted that it looks like the Corolla spy shot but it isn't, I double checked before I posted this. It has the same yellow camouflage as the Corolla pic but that's about it. The wheels and the roof are from the current generation.
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    Sorry, but that doesn't look like a Prius to me. Neither the front end nor the rear. And why would they remove the trim rings from the wheels? (If they take the hatchback design away they are so going to lose market. I for one would never buy the redesign but keep my current car until I die. I am never buying a sedan again. Not after the Prius hatchback design.
    This looks like a sedan.
    Could it be some other Toyota? The Corolla or even a mock up of a Camry? Too small for an Avalon.
  3. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(Godiva @ Jul 30 2006, 03:46 PM) [snapback]294706[/snapback]</div>
    If you showed a 1G Prius owner the 2G prius before it was released, they would say something like...
    Sorry, but that doesn't look like a Prius to me. Neither the front end nor the rear. And why would they remove the trim rings from the wheels? (If they take the sedan design away they are so going to lose market. Hatchbacks are synonymous with cheap in this market.
    This looks like a hatchback.
    There is no indication that the 3rd generation Prius has to or will look anything like the 2nd generation. Altho maybe they'll finally fix the seats and give it as good an interior as the 1st gen had.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I agree. It looks too much like a "car". I love the design of the 04-06 Prius and would not buy a sedan. Maybe if the sedan was 100% EV I would but thats a different story.
  5. wstander
    wstander New Member
    982
    Looks like a mocked up 'mule'. Companies do this to disguise new cars fo real-world checkouts.
    Couple of years ago, I was passed by an entire train of the then-new Toyota Tacomas wearing a bunch of plastic wrapping.
  6. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    i would think to get the 90s mpg they would have completely revamped... but then again a lot of consumers like it for how different it looks.
    looks disguised to me... they're definitely covering something up
  7. Godiva
    10,339
    <div class='quotetop'>QUOTE(galaxee @ Jul 30 2006, 03:17 PM) [snapback]294719[/snapback]</div>
    Why? I thought the Prius hatchback was shaped the way it was because it is the most aerodynamic shape. So moving away from that shape would make it less aerodynamic. Not something you would do if you're looking to increase gas mileage even more.
    I can see maybe doing some revamping to the mechanical stuff. But the not the shape.
  8. Tideland Prius
    16,445
    You do realise that manufacturers do use current bodystyles as a form of DISGUISE. Just because it looks the same, doesn't mean that's how the 2008/09 Prius will look like. It looks like they're testing the underpinnings at the moment. Given that the current model seem to fit well, that could mean that the new Prius will be based on the same chassis and thus we could expect the same wheelbase.
  9. Cheap!
    Cheap! New Member
    1,157
    My vote is that it is not the 2008 Prius.
  10. ceric
    ceric New Member
    1,114
    Fremont, CA
  11. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 30 2006, 03:14 AM) [snapback]294538[/snapback]</div>
    That looks like one of the worst photshop jobs I've ever seen! This is a joke right?
  12. Tideland Prius
    16,445
    <sigh>... obviously some of you still can't get pass the fact that they're using the CURRENT Prius body as a shell. It's the hybrid system/engine/suspension etc that they're testing. Who cares what the body looks like.
  13. RichBoy
    RichBoy New Member
    189
    thats not a Prius. and also, the Pruis will not change until the O9 model year anyway.
  14. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 30 2006, 06:46 PM) [snapback]294756[/snapback]</div>
    Well isn't that the whole point of the spy? I can barely tell that thing is a car, let alone a next generation prius.
  15. Godiva
    10,339
    <div class='quotetop'>QUOTE(RichBoy @ Jul 30 2006, 05:49 PM) [snapback]294761[/snapback]</div>
    Anticipated release in fall of 2008. Sometimes people mix up the years. I assumed we *were* talking about the 2009 new design....to be released fall of 2008.
  16. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(sl7vk @ Jul 30 2006, 04:13 PM) [snapback]294765[/snapback]</div>
    Ya well, good luck talking to Toyota telling them to test the car with the new style and letting photographers snap pictures. You can't tell them what to do. If they feel like hiding the real design from us, you can't do anything about it.
    But as I said above, you can deduce a few things from that like the wheelbase for example. I don't see any cuts in the body or other crude changes which suggest that the new Prius will probably keep the current chassis.
  17. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    What ever it is it has a lot of body putty on it. Look at the color!! Prius? not Prius? Who can tell/
