Square Oil Catch Can
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Jul 30, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Any reason not to install this square 500ml oil catch can? It has a sight glass to check the level, and it has a drain plug (although I assume that it wouldn't be too difficult to drop).
    (I don't see the link in Preview mode, so I don't know whether others can see it. The Amazon item no. is B07BQS1JG8)
  2. schmuber
    schmuber Member
    115
    85
    Georgia
    It violates the KISS principle.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Nope;).
    Use it as it is still a wide spot in the line:).
    Keep us posted on performance if you purchase and install it (y).
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I use that one except mine doesn’t have the fair filter
  5. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    What's the deal with the "breather"?
  6. tankyuong
    1,555
    662
    Central MO
    The breather will trip the cel
    Sappy likes this.
  7. Mendel Leisk
    41,962
    Adblocks seem to block Amazon links, at least here. Here's a screen grab:
    I would stick with non-vented style. Is there a non-vented square one? The square shape might simplify mounting, being more stable.
    FWIW, I went with Moroso 85474, but they're not cheap. :eek:
    (I took a bullet, turned off my adblocker to get this. Man there's a lot of dreck here.)
    #7 Mendel Leisk, Jul 31, 2019
    2014 Member
    30
    31
    MA
    Newhybridowner is in Michigan. Don't OCCs freeze in cold temps? Is a frozen OCC an issue?
  9. NewHybridOwner
    607
    283
    W. Michigan
    Prii (and most modern cars) violate the KISS principle. Just go back to side-valve engines with low compression ratios.
  10. NewHybridOwner
    607
    283
    W. Michigan
    The vent doesn't have to be used.
    Looks nice, but more than I want to spend.
  11. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    That one looks like you can drain it without a hassle? (In my case ease of maintenance means the maintenance might actually get done.)
  12. Mendel Leisk
    41,962
    Yeah, I drain in conjunction with oil changes, from below. I mounted on the lower cross beam, on a slotted angle bracket. Caution though: be sure to make the connection to that beam flexible, use some rubber washers, install bolts finger tight with a second nut torqued against the first to lock. The reason: that beam needs to flex, especially if you're using the front/centre jacking point, which is the underside of the beam.
    With the slotted angle atop the beam, and the OCC pushed up high in it's (supplied) bracket, it just clears the engine underpanel.
    Raytheeagle and wheezyglider like this.
  13. NewHybridOwner
    607
    283
    W. Michigan
    So I should forget about an OCC and just try to mop out the intake manifold regularly?
  14. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    What about the egr circuit then?
  15. NewHybridOwner
    607
    283
    W. Michigan
    Doesn't the EGR circuit still need to be cleaned out even with an OCC installed? Or maybe not as often?
    Is there any consensus that an OCC should not be installed in climates with the likelihood of hard frosts?
  16. Mendel Leisk
    41,962
    There's a Finland member who disconnects his in winter IIRC. Still I would try-and-monitor, not sure how freeze prone they are.
    I think an effective OCC will slow the rate of carbon build up in EGR circuit, but no hard data to confirm.
    I install my OCC about 18 mo back, and recently checked EGR pipe was absolutely clean. Only about 10k kms tho.
    Raytheeagle and Grit like this.
  17. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Bill norton called and he wants his tag line back.
  18. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    My OCC hasn't frozen, in more than 2 years and -15 degree F cold snap this past winter. Water condenses in it during the winter, but with all the solute in it, its freezing point is depressed. And it's heated whenever the engine runs.
    RMB, Raytheeagle and Mendel Leisk like this.
  19. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Heard some feller dump small amount of anti freezing wiper fluids in the can and kept everything in the can from freezing.
  20. Vman455
    539
    556
    The Middle
    You don't need to do that: any solute dissolved in water lowers its freezing point based on the amount of solute, not its chemical composition, and there's plenty of oil in there already.
