Squawker Mounting Hole Dimension
Discussion in 'Gen 3 Prius Audio and Electronics' started by ultraturtle, Apr 7, 2012.
  1. ultraturtle
    108
    81
    Peachtree City, GA
    Of those of you who have replaced their squawkers, has anyone kept the originals? If so, could you measure the distance between mounting hole centers?
    My car does not get in for another 10 days, and I'm fabricating brackets now so the speaker swap-out can go a little quicker when it arrives.
    Measurements taken from inseek's pictures show it to be roughly 3 7/16", but I'd like to verify before I get to work.
  2. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    I think it's about 8.5cm...I've got pictures but cannot seem to attach them to this post.
  3. WE0H
    WE0H Senior Member
    3,247
    528
    What you swappin the squawker for?
    Mike
  4. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    I bought 3way components CL-6E32 by CDT audio. Mid is 3". Should fit factory location just fine.
  5. priusFTW
    434
    Will do rears soon. Will update you.
    iPhone ?
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Are you swapping speakers or small children, the nomenclature is confusing??? :confused:
  7. drew935
    drew935 Member
    168
    23
    Nor Cal
    Here is what I did with the squawkers. Rip them out of the mounting brackets and mount the tweeters in them.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ clever. But I am glad I went with a 2-way cause the front really needed full range up high.
  9. WE0H
    WE0H Senior Member
    3,247
    528
    Have you guys listened to the 7.1 system in the 2012's? The sound stage is on the top edge of the dash. For a bone stock factory system, I am impressed.
    Mike
  10. bisco
    51,154
    i don't think the base plug in has that? either way, it's not much/any better than my 08 pkg II.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  12. drew935
    drew935 Member
    168
    23
    Nor Cal
    Spiderman, I only installed the tweeter so far and still have to complete the 6.5" in the front doors.
  13. ultraturtle
    108
    81
    Peachtree City, GA
    I finally got around to measuring the hole to hole distance referenced in the original post. It is pretty close to 3 1/2 inches. Mounting plates for tweeters or mids to replace the front squwakers can easily be fabricated from 16ga steel in an hour or two:
    • Print the attached file "Prius Squwaker Mounting Plates.pdf" on label paper and adhere to a 6" x 4" blank
    • Size center hole for your tweeter mount. Hole on pdf is for a 2" opening.
    • Cut with a 22-24tpi saber saw blade
    • Drill 1/4" mounting holes
    • Debur and sand
    Makes for solid mounts with little more effort than it takes to cut up the existing squwakers to use as mounts.
    BigMufasa74 and Correllaaron like this.
  14. Correllaaron
    Correllaaron Junior Member
    San Jose, CA
    Great post, I will use this template for some aluminum mounts this weekend!
