Squeaking noise when turning steering wheel left or right
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Wittyfull, Jul 5, 2022.
  1. Wittyfull
    Wittyfull Junior Member
    Houston
    My 2012 Prius V with 225K miles makes squeaking and slight clunking sounds when I turn the steering wheel left and right. Does anyone have any ideas what parts might be causing this noise? Rack and Pinion? Tie rod ends? Sway bar linkages? Other? Thanks.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Sounds like something inside the car with you. Could be a loose steering column plastic cover or it could be something functional like the steering wheel clock spring. I doubt it is a front end suspension part. I would have somebody look at it.
  3. Air_Boss
    Air_Boss Senior Member
    4,140
    1,154
    New Yawk
    Definitely an interior bind or squeak.
  4. Wittyfull
    Houston
    Hmm. Okay, I didn't even consider it was coming from the interior. I'll check the area where the steering column passes through the firewall. Thanks all.
