Squeaking sound coming from glove box with heater on
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by riban, May 22, 2015.
  1. riban
    riban Junior Member
    This just started appearing recently (seems to be just after I replaced the cabin air filter) where when I turn the heater on or A/C on I hear sort of a squeaking sound. Almost like a dying motor or fan. I have not really noticed an issue with air blowing out, I did at first think it was a little less powerful but believed that to be related to a different air filter possibly blocking a little more air than usual.
    The sound does come from the glove box area, switching from recirculate air does not affect it, the higher the fan the slightly higher the noise but not by much. I find it happens more with the heat on (usually turn the heat up to 31 and blast the fan in the morning). Sometimes it happens with the A/C.
    Any ideas would be helpful.
    Thanks,
  2. riban
    riban Junior Member
    Actually it seems the sound comes from either the AC or heater being on.
    49,455
    thats where the ventilation fan is.
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Most likely the blower motor bearing.
  5. bisco
    49,455
    unless it's just the filter wheezing.
  6. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Having the same issue with my 06' right now. When the climate control system is on, it's a little continuous squeak. May use some wd40 but I also don't want the interior to smell.
  7. bisco
    49,455
    check the fan blades to make sure nothing got past the filter.
