Squeaking/squealing sound coming from engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by randommonks, Mar 30, 2017.
  1. randommonks
    randommonks Member
    65
    37
    Houston, TX
    I just noticed today a squeal that sounds almost like a cricket chip but is almost constant. It starts immediately when the car is moving and gets louder when the windows are down, so I suspect it's coming from the engine. I can hear it at highway speeds but it seems to be more intermittent than at lower speeds. It almost sounds like a belt is loose or something. I can hear it on electric and gas modes and stops when the car stops. The noise is just as noticeable from the passenger side so I don't think it could be coming from a single tire.
    The car is a 2013 Prius with around 41k miles. Oil change done every 10k miles, give or take 100 miles, and tires replaced a few months back when the car had around 37k miles. I have an appointment at the dealership in the morning for them to take a look at it. I'm crossing my fingers that it's something covered under warranty or at least an easy fix. Anyone have any clue what it could be?
    51,155
    can you hear it with the engine running in park and the hood open?
  3. randommonks
    randommonks Member
    65
    37
    Houston, TX
    I've not been able to get the engine running while in park but will try to remember to listen for it when first starting up tomorrow.
  4. Tande
    Tande Active Member
    524
    310
    Mich.
    Does THAT not rule/out the engine as a suspect?? .......
  5. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Sure does. If the engine is off, and you hear it....well there you go.
    I would suspect a squeaky strut or sway bar link. Nothing life threatening
  6. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Yeah I don't think it's from the engine anymore. I sat with the engine running first thing this morning and no squeak until the car started moving. I'm sitting at the dealership now waiting for them to diagnose.
  7. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Something with the brake system seems to be the culprit.
  8. Mendel Leisk
    40,584
    Is there a pulsation to it, does that go up/down with vehicle speed?
    I'm kinda thinking something with the driveshaft CV joint boots, or the oil seals where the driveshafts go into the transaxle. Just guessing though.
  9. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Ok well if anyone bet that it was a worn out wheel bearing- you win! I had to leave the car at the dealership overnight since they didn't have the part but I should get it back tomorrow morning. It was happily covered under the powertrain warranty and they didn't make me pay the diagnostic fee either.
    Montgomery and Mendel Leisk like this.
  10. Mendel Leisk
    40,584
    Doh! I was going to include bearing in my list, then thought better of it. :oops:
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    That's what they all say :whistle:
  12. Jimi1976
    242
    124
    Denver, CO
    Nice!
    You got it early!
    I let my worn bearing go an entire year before turning to a grind, effecting MPG.
    Good thing the warranty is covering it (I replaced it myself....I imagine the dealer would charge at least $800)
    randommonks likes this.
  13. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    I wrote "wheel bearing" on a slip of paper (didn't have time to post) for my guess. If anyone doubts me, I can show you the piece of paper.
    amos, Mendel Leisk and Raytheeagle like this.
  14. Montgomery
    2,254
    2,241
    Orange County, CA
    Mendel, Mendel, we all depend on you!!!
  15. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Poor girl is going back to the dealership tomorrow for a similar issue. This time, it sounds like a metal rubbing against metal noise when the car is moving and a very distinct metal grind squeal when turning left but no noise on a right turn. We'll see what the dealership comes up with this time. Any bets?
  16. randommonks
    randommonks Member
    65
    37
    Houston, TX
    Apparently the dust shield on the rotor was tilted which was causing the noise. Spent an hour at the dealership and all noises have abated. For now....
