squeaky brakes after rain or carwash
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Shooter8, Sep 20, 2025 at 3:06 PM.
  1. Shooter8
    Shooter8 Junior Member
    16
    central Arizona
    2013 Prius v wagon
    2013 Prius V, 160K. We recently replaced the fluids, brakes, and head gasket. Head gasket was a biggy.
    Anyway, we noticed that the brakes squeak lightly for several miles after some rain even while brake pedal is not depressed even if the car was parked inside during the rain.
    We have heard of several sources of this noise, including light rust on the rotors, which doesnt make sense: the rotors on my pickup do not squeak under similar conditions
    Is there a definitive causes of this annoyance?
    51,506
    doesn't a correct brake job include some kind of anti squeak clip or something?
    i doubt it is rust, but you can clean them up with light braking in neutral if needed. you can't compare a hybrid to a full gasser, because the gasser uses the pads all the time when braking, thus, no rust.
