squeaky door panels
Discussion in 'Gen 2 Prius Main Forum' started by mr.whit, Jul 9, 2006.
  1. mr.whit
    mr.whit Member
    117
    Michigan
    I have a 2006 Prius w/#7. Does anyone else have squeaky door panels? If the windows are down it is less but still there… If someone rests there arm the door panels they squeak. I know, I know don’t rest your arms on the door panels.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(mr.whit @ Jul 9 2006, 01:10 PM) [snapback]283380[/snapback]</div>
    Yes, it happens to mine too. It is annoying and one day I will a solution to quiet it.... I think the squeak comes from the new interial layer touching with the plastic panel. When I took off the door panel to install the leather, I saw how the new layer was added.
    Dennis
  3. Swingshiftworker
    Swingshiftworker Junior Member
    97
    San Francisco
    <div class='quotetop'>QUOTE(mr.whit @ Jul 9 2006, 12:10 PM) [snapback]283380[/snapback]</div>
    I have a squeaky (or rattling) driver's door window which is really annoying only because the Prius is really quiet. The noise goes away (or is masked by road noise) when I lower the window an inch or so. It only squeaks or rattles on rough road surfaces when the window is up. I haven't looked closely at it yet, but I am planning to try to get it "fixed" at some point.
  4. jenlynmc
    jenlynmc New Member
    <div class='quotetop'>QUOTE(Swingshiftworker @ Jul 10 2006, 12:46 AM) [snapback]283669[/snapback]</div>
    My drivers side door also squeaks--only when someone has their arm rested on it. My husband always puts his arm there when he drives and the noise makes me crazy!
    The dealer told me he could take the panel apart and put some felt in there to stop it. Any thoughts on this? Would it be cheaper, easier, better to get a new husband?
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Before you trade in your hubby, and the rest of you go nuts from the noise, you might try some 303 Protectant sprayed in the joint between the top and bottom halves of the door plastic panel. It may lubricate the two panels and stop the squeek.
    If one of the clips holding the plastic panel to the door metal is squeeking, the plastic panel has to be removed and lube/padding put in to stop the noise. If you're under warranty and trust your dealer, they can do it, or you can do it yourself following the directions in the audio forum.
    The 303 is good for all your plastic. I am not a paid endorser.
  6. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    It actually appears as though there is a hollow spot right under that point on the panel. When I push along the top of the panel, it only squeaks at that point, and I can hear/feel weakness under that area.
    Also, from my elbow, combined with the heat, I have a slight dimple forming there as well.
    I plan on addressing both issues soon when I remove the panels to change the speakers.
  7. mr.whit
    mr.whit Member
    117
    Michigan
    Thanks for the input, I am not alone with this issue... :huh:
  8. FJRCRAZED
    FJRCRAZED New Member
    100
    S.E PA
    Yup, It does go away on real hot days though
  9. sabujo
    sabujo New Member
    Oporto, Portugal
    Squeky too here... Most anoying when you are showing your new car to a friend.
  10. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Mike,
    I have the same problem and added a new post yesterday.
    How did you fix it?
    Any tips on removing the door panel?
    Ken R.
    <div class='quotetop'>QUOTE(mssmith95 @ Jul 10 2006, 02:29 AM) [snapback]283706[/snapback]</div>
  11. Bill Merchant
    4,096
    81
    Ken, you've revived a thread that was dead for a year.
    Look in the Audio and Electronics forum for speaker replacement instructions - if you can get to the speakers in the doors, you have the plastic interior panel off.
  12. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 1 2007, 01:19 PM) [snapback]471048[/snapback]</div>
    Bill,
    I found those messages, but the link to the door panel removal was broken.
    Ken R
