Squeaky Front End
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Teacherjoe, Apr 3, 2015.
  1. Teacherjoe
    Teacherjoe Junior Member
    29
    Okay, I have a squeaky front end on my 2005. I have changed the front struts but it still squeaks when turning or when going over a bump. Any suggestions?
    51,140
    someone replaced all the bushings and lubricated as well. another had a squeaky hood hinge.
    #2 bisco, Apr 3, 2015
  3. JC91006
    16,672
    8,518
    When you replaced the front struts, didn't anyone check for worn parts? It would be crazy to go back in there again, super labor intensive.
  4. Teacherjoe
    29
    Let me rephrase this, I replaced the front strut assemblies, including the springs and all... What other parts could be worn out after that? I am doing my own servicing as our dealership is wanting way to much money for repairs/service/maintenance. I'm getting pretty good at it, this is new territory though (strut assemblies). Thanks in advance,
  5. yibo829
    yibo829 Junior Member
    84
    Check the lower control arm bushings.
    iPad ?
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    if the ball joint boot is torn and/or the joint gets dry it can squeak. I would get someone to turn the steering wheel to make it squeak and listen to try to find where its coming from.
