Squeaky passenger seat. Does anyone else have a passenger seat that squeaks? It is fine when someone
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kritzie1, Dec 13, 2009.
  1. kritzie1
    kritzie1 Junior Member
    CA
    I have a 2008 Prius. When I purchased the brand new car I heard a squeak and they couldn't find it when I brought it in. So, I just pushed the seat back and layed it flat. That helped. Now, that doesn't help. It always squeaks and it's driving me crazy. Again, I took it in and they could not find the problem. Any suggestions?
  2. jsnschmasn
    jsnschmasn New Member
    17
    St. Louis, MO USA
    Re: Squeaky passenger seat. Does anyone else have a passenger seat that squeaks? It is fine when som
    I have a passenger side squeak when the car is very cold. Once warmed, the squeak goes away. I've had a few toyotas and have yet to find one that doesn't rattle or make some odd noise. When they try to fix anything on the interior, I typically receive the car back in worse shape so I decided to live with the squeak in the seat and the rattle behind the driver's side air duct.
    GOOD LUCK!!
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    kritzie1,
    :welcome: to PRIUSchat. :cheer2:
    After a year on the road, my '08 developed an annoying squeek/weak
    groan in the passenger seat. After 3-4 months it magically went away.
    Shortly thereafter it started in the driver's seat. It's been going on now
    for ~5 months... irksome but survivable. :(
    FWIW, there is a TSB on this condition. It looks pretty complicated. I
    haven't gone to a dealer to have the procedure done because I'm not
    confident that in the seat disassembly/reassembly process they won't
    screw something else up... scratches, tears, etc. :mad:
    Here's the TSB: View attachment Prius___Front_Seat_Squeak-1.pdf
    Hope this helps.
  4. TrailblazingScot
    TrailblazingScot New Member
    Essex
    But why is the blasted seat squeaking at me when my girlfriend is on the passenger seat?
  5. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Is the squeak coming from the underside of the seat or near the headrest? Is it a subtle intermittent sound or an annoying, inescapable din? ;-)
  6. TrailblazingScot
    Essex
    I think it is the underside of the seat and it is not subtle when it gets going but very evident and annoying. Music needs to be playing!!!
  7. don_chuwish
    816
    182
    Southern Oregon
    LOL, and here I thought you were making a crack about your girlfriend being squeaky. Very sorry! I think I have the same problem with my passenger seat - much worse with a passenger in it, but it squeaks even when empty. I'm thinking mine is coming from the plastic trim on the door side, not the locator pin as specified in the TSB.
    - D
  8. don_chuwish
    816
    182
    Southern Oregon
  9. don_chuwish
    816
    182
    Southern Oregon
    Yep, for me it was that plastic trim. Following the TSB (T-SB-0390-08) I found where the two plastic pieces were rubbing - I could even see a worn spot. Instead of having the dealer replace the trim I just cut off a tiny bit of plastic with a box cutter. No more squeak. TSB found in the thread linked above, but I'll repost it here for convenience.
    - D
  10. TrailblazingScot
    Essex
    If this works, you're my hero.
    If not, well, lets not even go there ;)
  11. don_chuwish
    816
    182
    Southern Oregon
    For clarity, here's an ultra up close photo. You can see where I trimmed away some plastic and also the worn spot from the rubbing.
    - D
    uart likes this.
  12. blet
    blet Junior Member
    Boston, Ma
    I had my squeaky passenger seat on my 2008 repaired at the dealership yesterday. This was the third time I had it in for this problem going back over a year. I showed the service advisor TSB 0390-08 to bolster my case as they said the sqeak was as a result of an HD radio I has installed! Anyway, the part that they replaced is Part #71811-52140-B1 Shield, Fr Seat Cush. This part no. is different from the one listed in that TSB. I've only driven the car from the dealership to my home and so far so good. I'll update you if the sqeak returns.
  13. Brodie
    Brodie New Member
    162
    Rhode Island
    I also have the cold-car-seat-squeak problem. Thanks Don for the very helpful picture...I might try to do what you did if it really starts driving me nuts.
  14. macmaster05
    macmaster05 Senor Member
    4,050
    729
    My hatch sounds like its squeaking when I pull out of my sloping driveway in the morning. Does anybody know what this is?
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    The 2006 has this problem, only when it is pretty cold outside, definitely below freezing, only when there is a 180+ pound passenger. Of course the other passenger choices are teen girls. The younger one weighs 120# and the older one doesn't even crack the 100# mark so the 180# isn't a specific minimum :) Shifting weight off the outside edge usually stops the squeak.
    After reading this thread, I'm guessing the plastic rub TSB. Thanks for the tips!
  16. TrailblazingScot
    Essex
    Okay I finally solved it and it was really simple.
    I got some thin cardboard, tore it into shape and put it between the plastic parts rubbing at the back.
    No more squeak!!! Woohoo!!!
  17. suirp91257
    suirp91257 Junior Member
    33
    Indiana
    We have a 2006 Prius that has developed a squeak on the passenger side also, I believe it is the plastic base of the seat, rubbing against other plastic...seems to only do this when cold...once interior of car is warm squeak goes away...Plastic must expand or something.When I push on the bottom plastic part of the seat I can make the squeak stop...again only when it's cold.
  18. Jerry Ku
    Jerry Ku Junior Member
    San Francisco, California
    This worked for me! Thanks Don!!
