Squeal after turning motor off???
Discussion in 'Gen 2 Prius Main Forum' started by gene4655, Jan 25, 2010.
  1. gene4655
    gene4655 Junior Member
    51
    Our 2006 seems to be increasingly angry at our turning the motor off and going in the house! Immediately after the ignition is turned off, it starts squealing. It did this a bit earlier, but now it seems to squeal for 12-15 seconds. Is the increasing length of the squeal a sign of trouble? thanks for advice.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Open the hood up. Have someone shut off the car while the motor is running and see where the squeel is coming from. Most likely the coolant transfer pump behind the drivers side headlight. Known issue.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    It sounds like the coolant heat storage pump. See this for more.
  4. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    Yes, as the above posters have guessed, it's probably the coolant transfer pump. Pearl has been doing it for 18 months. Toyota Canada won't do anything. I -think- Toyota US replaces the pump on warranty.
  5. Patrick Wong
    18,198
    6,461
    The noise is due to the coolant heat recovery pump. If your car is no longer under warranty, don't worry about it.
    BTW, the coolant heat recovery pump is located near the CHRS canister. Both are located in the fender well, in front of the LF tire. You need to remove the fender liner in order to access the pump and canister.
    The pump behind the driver's side headlight assembly is the inverter coolant pump.
  6. yes.ittransforms
    yes.ittransforms 100K!!!!
    62
    Las Vegas NV
    I second the above comments
  7. gene4655
    51
    Many thanks for the information. Going to dealer this week to see what they will/can do. As of now, I'm still under the 60 month, 60,000 mile leve. Again, thank you.
  8. Patrick Wong
    18,198
    6,461
    In that case, you are in luck because the coolant heat recovery pump is covered under the 5 year/60K mile powertrain warranty. See T-SB-0087-08 which is posted here.
