Squealing seemingly from front end, maybe right side
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by 2023p, Aug 27, 2023.
  1. 2023p
    2023p Member
    112
    66
    Here
    2023 Prius
    20k miles ish. Was difficult to capture audio/video as the sound is faint.
    Seems to only happen, from cold starts(maybe), 0-15 mph maybe at most.
    Seems interment. Thought maybe control arm, brakes, belt.. but I have absolutely no idea what I'm talking about.
    Not sure what else to say.
    Anyone else had this type of noise and conditions? On any hybrid or Prius or specifically the 5th gen.
    It's varying high pitch tone, can't imagine it's the brakes.. butttt logic says.
    There a way to test drag? Or just have brakes checked under warranty? Or something
    Thought about shifting into neutral the next time I heard it happening to hear if it stop making the noise suddenly. But not really sure what that might mean if true.
    Thanks.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    While the noise is present, step on the brakes.....firmly.
    If the noise changes significantly, get them checked.
    It is not unusual for disc brakes to have a slight squeal before the first stop after sitting unused overnight.
    There likely also are "wear indicators" on the pads that are SUPPOSED to make a squealing noise when the pads
    are worn down.
    NOTE: Since you mentioned warranty......by all means have it checked AND DOCUMENTED by the dealer sometime soon, just incase it actually fails after the warranty expires.
    2023p likes this.
  3. 2023p
    2023p Member
    112
    66
    Here
    2023 Prius
    Thank you Sam!
