Squeel when making sharp turn
Discussion in 'Generation 1 Prius Discussion' started by SeattleStar, Jun 19, 2009.
  1. SeattleStar
    SeattleStar New Member
    Seattle
    2002 Prius
    I have a 2002 Prius with 112k miles. Just this past week I noticed that when I make sharp turns around corners there is a light squeeling noise. My assumption that it is a belt that is starting to go bad. Looking in the engine compartment I notice that none of the belts are easy to get to. Does anyone have any advice or experience with this? Thank you in advance!
  2. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    me too on my 02 gen 1 - same noise when i do a uey in front of my house to park on the right side of the street - slow turn but tight
  3. Patrick Wong
    18,200
    6,472
    There's one drivebelt, which powers the engine water pump and the air conditioning compressor (Classic only.) Since this has nothing to do with steering I doubt that the drivebelt is the cause of the squeal sound that you hear.
    What is the tread depth of your front tires? My guess is that they are worn and that one tire is slipping as you make a sharp turn, causing that noise.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    It's the outer CV boots. The folds rub on each other a little
    bit in a tight turn. The first time you hear this it sounds
    absolutely horrendous, especially when it's in the middle of a
    snowy night ... but I got the car in the air a while later
    and debugged it; it's largely harmless.
    _H*
  5. fred garvin
    376
    56
    northern virginia
    treads fine
    CV?
    So not indicative of an inpending disaster?
    Thanks.
  6. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    "CV" = "Constant Velocity" joint.
    All front wheel drive cars have them.
  7. fred garvin
    376
    56
    northern virginia
    thanks
    so the sqealing is not a harbinger of a $1200 repair or a impending accident?
