Squeezing out 37.1 MPG around town
Discussion in 'Gen 2 Prius Main Forum' started by debrasnell, Oct 30, 2007.
  1. debrasnell
    debrasnell New Member
    32
    I have tried my best to improve my driving - inflated tires to 40/42 - BUT I can't seem to pull off anything better thaan 37.1 MPG unless I drive to the Flat Lands... I have yet to see another Prius driver to talk to locally, even though it seems there are hundreds in my town.
    I was in the Flat Lands last weekend and a twin car pulled up next to me in a parking place. I couldn't even bring myself to ask what gas mileage they got as I didn't want to feel jealous. sigh.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It would only be worse in a normal car. Keep telling yourself that.
    Tom
  3. richard schumacher
    7,663
    1,038
    United States
    Are you pulsing-and-gliding?
    Do you ever shift to "B"?
    Is the oil overfilled?
  4. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    How long are your trips? Short trips are MPG killers.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(debrasnell @ Oct 30 2007, 01:12 PM) [snapback]532482[/snapback]</div>
    Here is a tip driving in hilly area. When going uphills, do not accelerate lower than 25 MPG. Consumption screen clearly shows and it is very easy to read. Prius can climb pretty steep hills at 55MPH and still get 25MPG. When going downhill, use stealth warp (left up your foot and gently put the pressure back). You can see on the Energy screen that only the Battery is providing power to go down the hill and using no gas. If you gain speed, let it gain. Also when you climb, let the car slow down to acceptable speed while not blocking traffic behind you. Overall, you should average 50MPG. The key is to plan ahead to avoid sudden change in power demand (light foot).
    It is also good to know the limitation of the regen braking. Slow down about 2 MPH per second. That's the max rate the HV battery can take. Brake any faster and the friction pad will kick in, throwing away the gas you used to accelerate.
  6. debrasnell
    32
    <div class='quotetop'>QUOTE(richard schumacher @ Oct 30 2007, 12:34 PM) [snapback]532496[/snapback]</div>
    I read your post on the way out and shifted to 'B' for the first time... My MPG's went up to over 53 MPG... Can I leave it on 'B' all the time? I *did* read the manual - it says to leave it on 'D'... Clearly I need a basic education on when it's OK to drive on 'B' and when I need to drive it in 'D'. :unsure:
    Thanks for your help.
  7. debrasnell
    32
  8. Bob64
    1,540
    92
    Virginia
    I think he was asking if you had it on B because it usually screws up your milage...
  9. JimboK
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(debrasnell @ Oct 31 2007, 12:09 AM) [snapback]532751[/snapback]</div>
    http://www.techno-fandom.org/~hobbit/cars/b-mode.html
  10. gazz
    gazz Member
    216
    Coventry, UK
    <div class='quotetop'>QUOTE(debrasnell @ Oct 30 2007, 11:09 PM) [snapback]532752[/snapback]</div>
    Don't use B it is an aid to going down steep hills it will in fact be less efficient then just using your brakes. Most of my driving is in hills, the Prius is efficient on the flat but with careful driving you can get even better millage on hills. Search this site and read up on the various techniques and the way the Prius works and it will all start to come together.
    Gary
  11. patsparks
    10,664
    567
    Adelaide South Australia
    Not far from home, on my way home I have a long steep up hill followed by a valley crossing, it always gets me a good mileage and I hit the flat run home with a green battery and get through the back roads to home on mainly that well charged battery.
  12. Traffic
    Traffic New Member
    Living in Florida, (Competely Flat ) I almost always get 50mpg plus or minus 1mpg. On a recent trip up to Pittsburgh Pa I got 47mpg on the trip up and back (75 to 80 mph ).
    The intresting thing is that on two tanks while driving around Pittsbugh, ( Known for its hills ), I got 56mpg. That is the highest I have ever got. The only differance is that half the time there I was without air conditioning while in Florida I almost always have it on.
    I also noticed that in Pittsburgh I had a lot more times when I had full green bars on the display.
    To sum up, I think the hills helped my mpg.
  13. richard schumacher
    7,663
    1,038
    United States
    Eek! No, you should *not* use "B" in normal driving. It should be used only to avoid riding the brake pedal on a long downhill, for example when coming down Mount Hamilton or Mount Wilson. In everyday driving "B" won't damage anything but it will reduce your MPGs.
    Now I'm trying to figure out why you would observe an increase in MPGs the first time you used B. Are you reporting the maximum figure seen on the instantaneous display? If so, don't pay a lot of attention to that; what matters is the per-tank average value on the display. (Flip back and forth between the "Energy" and "Consumption" displays to see the difference.)
    The best single piece of advice about driving style to improve MPGs may be to use the brake (and B) as little as possible.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Grass Valley is a nightmare for maxing out MPG in my opinion. The LONG hills make for a rough commute and the fact that most people freak out when you try to drive the speed limit and they tend to ride you pretty hard on the one lane portions.
    Sacramento in general is tough because there are few areas where you can drive slowly and going slower than 65mph in I80 is just plain dangerous! lol
  15. koa
    koa Active Member
    980
    45
    Hawaii
    We are getting about 37 mpg also. Live on a hill with hairpin turns so must slow way down. Wife works close to the bottom of hill so don't get much freeway driving in to average up. 99 Camry got 18 mpg.
  16. Miss_Taz
    Miss_Taz New Member
    153
    Pittsburgh, PA
    I drive mostly in the quite hilly area in Eastern TN (Maryville/Alcoa), and around "town" I only usually get in the low 40's.
    If I end up going to the city (Knoxville) via highway, that'll bring me up into the mid 40's.
    My biggest problem is the short trips. When you live in a smaller city like this, everything is so close that even bunching trips together is a short ride...
  17. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    <div class='quotetop'>QUOTE(Miss_Taz @ Nov 1 2007, 06:03 PM) [snapback]533438[/snapback]</div>
    There's an easy answer to that: For short trips, use a bicycle. In my opinion, that means any trip shorter than 5-10 miles. Unless it rains or a bicycle just doesn't do the job. My daily commute is 2*5 miles, increasingly by bike. It gets to be a habit.
  18. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Someone already alluded to this, but you might want to give this a read:
    http://www.techno-fandom.org/~hobbit/cars/sweet/
    Hobbit gives a pretty good summary here of how to try and keep the engine in the sweet spot. My quick summary is climbing up hills try to never get below 30mpg or so. On the down hills try to keep below 75mpg. If you pick up too much speed, alternate between <75mpg and warp stealth (no bars or slight charge/electric mode only). His basic idea seems to be that this keeps the engine in an optimal zone, and sweeps the "CVT" ratio. If you go below 30mpg the engine revs and efficiency drops. If you go higher than 75mpg with the engine running you are just burning gas and not really making much useful power due to too low RPMs. Note that these mpg numbers are just estimates of where the system will move in and out this more efficient mode. At speed slower than ~40 the mpg numbers shift lower. If you do this at higher speeds for a while you can get used to the sound of the engine when its in this rpm band. Then you can try and maintain it during acceleration as well. If you can match this to your hills, so that you are bleeding off a little speed on the uphills, and attacking the bottom of an uphill with a little extra speed all while maintaining this rpm band you might see some significant improvement.
    I'll freely admit I'm still a novice, but after adding this method into my routine I'm seeing much more impact than I would have predicted. Previously I have really just been trying the "common sense" stuff. Don't go too fast, accelerate and brake slowly & smoothly, bleed off some speed uphill, carry speed into uphills etc. I have a fairly short (7 mi) mostly freeway (~63mph) commute with gentle hills and have been averaging ~50-51mpg for weeks. I started "hobbiting" a few days ago, with 50.5mpg @ ~100mi on the MFD. I'm now at 53.7mpg @ 222mi. I would think the effect could be more dramatic in a hillier area, where you might easily be spending more time in the <30mpg and 75-99 mpg "red zones". I don't think I've achieved the 63mpg@63mph stage of enlightenment yet, but I'll keep working on it B)
    Rob
  19. Ducati Guy
    Ducati Guy New Member
    South Salem NY
    I am brand new to the Prius world. So far i am loving the car. 2007 with 212k. I drive all day. Usually about 20-30 miles of highway to get to my starting point for my day. Then it is stop and go, stop and go for the next 5-6 hours. Often times only a few minutes between each stop. Then after a day of that it is another 20-30 miles highway back home.
    I have been averaging 42 MPG. I have no idea if this is good MPG for this car. But it sure beats the 20 MPG I was getting in my Subaru.
  20. gator1976
    gator1976 Junior Member
    illinois
    I get avg of 40mph in town and 65mpg at 55mph and use B as a brake with light to moderate friction brake, seems to regen faster
    2013, class 3
