Squirrel Damage
Discussion in 'Prius c Technical Discussion' started by Daniel Bricker, Jun 30, 2023.
  1. Daniel Bricker
    Daniel Bricker New Member
    AR
    My 2013 Prius C started running rough this morning and barely made it to my office. When I opened the hood, I found a squirrel and squirrel related damage. Looking at the pictures, do you think I can just replace the cap (not positive what it is called) and splice the wire? Thanks for any help.
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Looks like they ate the wires leading to the connector for the ignition coil on cylinder #1. I would cut a matching connector off of a junkyard car, splice it onto your remaining wire harness branch and spend the rest of the day doing anti-squirrel things, because chances are what they ate didn't kill them.
    You could use any of the four coil connector branches from a donor car, and it doesn't even have to be a Prius c. Lots of other Toyotas use identical connectors for the coils.
    Daniel Bricker likes this.
  3. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    The price we pay for reducing the coyote population. :(
