SRS Acc Fuse - Which Slot?
Discussion in 'Generation 1 Prius Discussion' started by jamesprius, Jun 9, 2024.
  1. jamesprius
    jamesprius Member
    108
    San Jose, California
    2001 Prius
    I
    When diagnosing a drain. Removed a fuse and forgot which slot to insert into.
    Which slot should the 10A red fuse go into? The bottom left slot or the one immediately above it?
    Based on the diagram it should be one directly above the bottom left. SRS ACC 10A. Is that correct?
    Leaving it out doesn't seem to do anything. Not sure if its just unused on this model.
  2. ronlewis
    ronlewis Active Member
    865
    178
    texas
    2001 Prius
    It doesn't do anything because it powers the seatbelt/airbag sensors. To test, plug in the fuse and drive the car into a wall. :)
    jamesprius likes this.
  3. jamesprius
    jamesprius Member
    108
    2001 Prius
    I
    Ah, no wonder.
    So 2nd slot up from the bottom left correct?
    ronlewis likes this.
