SSC50P
Discussion in 'Gen 2 Prius Main Forum' started by scrubjay1, Jan 20, 2006.
  1. scrubjay1
    scrubjay1 New Member
    :angry: Ever since the SSC50P, mileage has been lower. It dropped from 52 mpg to 42, then has slowly come up, but is hanging around 48. Tire pressure is checked regularly. Temps are the same as last year at this time. It's been a month since the service. The service manager says it couldn't be the service. It must be the gas or the weather. He says I'm the only one that has complained. Please give me some feedback on this.
  2. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    Pardon my ignorance, but what's an "SSC50P"? If it's a servicing, could it be that they overfilled your oil during the change, and you've been burning it off?
    Dave
  3. scrubjay1
    The SSC50P is the special service campaign that recalled some late 2004s and early 2005s to reset computers because of stalling problems on some cars.
  4. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I've had the 50P service/reprogram (for the stalling issue) done about 2,000 miles ago. Still at 46 MPG, with a couple of tanks at 41 MPG. But weather has a big influence here (cold @ 10 degrees F or colder, then 50 degrees the next day!) Plus I'm running snow tires that make the car stickier, for lack of a better term. Car just sems to not roll as easy, engine works just slightly harder to get me going, etc.
    In short, can't wait for warmer temps and regular tires!
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Mine was done about 2000 miles ago and I have noticed no change in mileage or performance.
  6. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Since I got the update I've had a big increase in mpg. On warm days with slow trips I am almost getting my best summer mpg but with winter gas!
  7. Tideland Prius
    16,159
    Give it a 1,000 miles to return to "original" state. Let the computers sort themselves out and adapt to your driving style.
  8. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    i knew this would come up. as did a lot of the techs at the dealerships.
    the "is it SSC 50P or is it low temps/winter formula gas?" question.
    any other things done? tire rotation, new tires, etc? my guess is winter formula gas, but posting your location will help.
  9. jeromep
    jeromep Member
    827
    Eastern Washington State
    The problem with any search for the genesis of a problem is the fact that multiple factors are usually causing the problem you want to solve. In this instance the recall occured about the same time that many areas move over to winter gas. On top of that colder temperatures, worse road conditions all work against high mileage.
    I have not experienced any significant change in mileage since the SSC was done. I'm however experiencing my normal fall/winter mileage drop, which is pretty significant for me. I expect that my mileage will increase as spring comes and I will probably get better mileage this next spring/summer than I did last year. However I don't think there is any connection between the SSC and a mileage drop. I'm totally inclined to believe that any mileage drop you are experiencing right now is based on the time of year it is.
  10. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    If there was any effect the 50P improved my mileage. I'd like to think it's just me getting smarter thought :)
    Certainly no bad effect.
  11. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    My mileage is down as well since the SSC was performed about 4 weeks ago.
  12. Tideland Prius
    16,159
    ok, I did a similar update. The Canadian version (whatever that code is. We tend to have longer code names) back in Dec 19. So far so good.
