St. Louis, MO Mechanics that know Priuses
Discussion in 'Gen 3 Prius Main Forum' started by KevinG, Mar 1, 2025.
  1. KevinG
    KevinG Junior Member
    St. Louis, MO
    Anyone know of any independent shops in St. Louis that know Gen 3 Prii pretty well? Other than Auto Evaluators. I know they’re supposed to be exactly this, and judging by the number of older Prii they had in for service maybe they are. But I went there once and…let’s just say that was all it took for me to learn that I do not trust them to be fair and honest at all.
    I have been to JAMCO a few times, but they don’t want to touch more than the basics (oil change, tires, brakes, etc) on Prius.
    Anyway, my wife’s 2012 Prius has almost 130k miles and recently had the shakes on startup. We had it happen once or twice before a couple years ago, but it stopped doing it on its own. The more recent time it happened, I scanned for codes and it showed P0302 (cylinder 2 misfire).
    So I’m concerned that it needs a thorough EGR & intake cleaning.
  2. KevinG
    St. Louis, MO
    Nobody?
  3. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    A misfire in a cylinder may be related to the spark plug, ignition coil. Have you checked this?
    Are you far from servicing cars, even "at all"?
  4. ASRDogman
    ASRDogman Senior Member
    7,115
    3,713
    You need to pressurise the coolant system and use a bore scope in the spark plug hole
    for each cylinder and check for leaks.
    It is possible it could just be the spark plug, and/or coil. You could switch the #2 plug with the #3 or 4
    and see if the misfire changed to where it happens. If it does, you can be pretty certain it's a bad plug.
    At 130,000 miles it's due for a plug change,
    If it stays at #2, it could be the coil, switch it also. If it stays on #2, you can be pretty certain it's a head
    gasket failing.
    Cooler temps out and hot engine can cause moisture in the intake that caused the rattle and sometimes
    a misfire code.
    Sorry, can't help you with finding an honest shop....
  5. Roadie_
    Roadie_ Junior Member
    30
    KY
    In STL Check out Jamco (Japanese Auto Maintenance Co) or Import Auto. Both shops are independently owned, and specialize in Japanese vehicles. Both are quite honest.
    Edit: Just saw your comment on Jamco. Surprised at that. Check out Import Auto.
  6. bbrages
    bbrages Member
    162
    47
    St. Louis
    I live in StL, but I'm strictly DIY.
    However -- I do know the owner of Steger Service has a Prius V, and he replaced his son's 2010 Prius head gasket about a year ago. I don't know if that means they know hybrids, but the owner does have at least some experience with Prius head gaskets.
  7. bbrages
    bbrages Member
    162
    47
    St. Louis
    How is your coolant level looking?
  8. Mendel Leisk
    40,467
    Yeah, head gasket.
    That should be done every 50k miles. Do clean it, in conjunction with the head gasket, but don’t kid yourself that it’ll somehow “fix” the head gasket.
    several relevant links in my signature. Last link is the full engine section from repair manual. (On a phone turn it landscape to see signatures)
  9. bisco
    51,024
    Qualified hybrid mechanics are hard to find
