Stages Of Warmup In The Gen 5 HEV?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Apr 10, 2026.
  1. VelvetFoot
    VelvetFoot Senior Member
    1,337
    521
    New York State
    2026 Prius
    Maybe it's because it's getting warmer outside, the window is open a little, I'm not listening to the radio, or whatever, but it seems that I hear that sound where the timing is retarded ie, weak power, RPMs go up. This is when the engine is warm. Also, sometimes I see the engine rpms go way low, the EV light isn't on, but the SOC% is going down. The engine is not cold at this point. I know, not very scientific, but I didn't notice this stuff when it was cold out.
    Thoughts?
    Gen3:
    Gen3 warming up stages | PriusChat
  2. futurist
    futurist Member
    57
    134
    United States
    2024 Prius
    Cold air drawn in and used to make ICE power, all things being the same, will produce more specific output than warm air. Thing is, things will not be the same around those two parameters... and if so, not for very long.
    I've noticed w\ my 5G HEV... warmup is longer at 68F ambient (according to the temp display in the dash, who knows how accurate it is; haven't checked after it) than 72. My way out of my gated comm'y's a certain fixed distance, up- and downhill slightly. When the car was new, the warmup phase of ICE firing would last until almost exactly when I'd come upon a speed bump (~80 - 85m). This did not vary whether ambient was low 70s or high 60s -- in the first year and half.
    Now w\ 20K, it needs another 30m or so (the next bump) before the ICE shuts down, warmed. These are some of those mitigating factors mentioned earlier.
    Are your plug electrodes beginning to wear? Are they torqued properly? Is your emissions control system sending bad data to the PCU, because you top off your fuel tank with multiple clicks at the nozzle (don't do this, causes raw fuel to enter the system and flood the charcoal canister... which then cannot store fuel vapours and will not supply the ICE w\ proper richness it expects). Is your air filter dirty? Is your oil spent and full of water? All these things can affect ICE performance more when warm than cold... and will cause the PCU to make adjustments accordingly, biasing emissions over fuel economy.
    Priuses have Atkinson-cycle ICEs, so a lot more sensitive to conditions than Otto-cycle. Which is why only a few automakers use Atkinson-cycle ICEs on their own, as not part of a hybrid drivetrain. Honda's current Civic has a base model LX with a 2.0L naturally-aspirated one... and it's 16bhp weaker than the 1.5L turbo it replaces -- not to mention will not like being driven hard. The Old Man is truly dead :cautious:
  3. VelvetFoot
    1,337
    521
    New York State
    2026 Prius
    Now that it's warm, I'm seeing a lot of this behavior.
    Engine revs maybe 2000 rpm higher than normal, low power for a while.
    Also the electric motor runs longer-not in green light EV mode-an engine rpm value is shown, but it's low. I think the SOC is dropping at that time as well. All with a warmed up engine.
    I'll have to read that link in detail again.
  4. Winston Smith
    Winston Smith Active Member
    426
    297
    OH
    2024 Prius
    LE AWD-e
    I have no first hand experience with this engine, but Honda cites a power peak at 6400rpm. That's not bad. If the Honda engine has modest low speed torque (which I understand to be part of the problem with more widespread adoption of Atkinson cycle engines), I get the picture of an engine that only really shines when it is run hard. It might be an interesting engine in a lighter car if it had a manual transmission.
    Unfortunately, it has a CVT that does a lot to obscure engine characteristics.
    Because the power split isn't strictly binary a warm engine with modest power required but not enough charge to turn the engine off should leave the electric motor providing a propulsion assist and long effective gearing.
    I often pull into my garage with stratospheric trip efficiency indicated and a low SOC because the approach to may garage is all low speed electric only travel. That has my engine switching on within the first hundred feet when I depart.
