Stainless steel spacecraft
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Jan 22, 2019.
  1. bwilson4web
    16,102
    Source: Elon Musk Interview: Why the Starship Is Built of Stainless Steel
    On the windward side, what I want to do is have the first-ever regenerative heat shield. A double-walled stainless shell—like a stainless-steel sandwich, essentially, with two layers. You just need, essentially, two layers that are joined with stringers. You flow either fuel or water in between the sandwich layer, and then you have micro-perforations on the outside—very tiny perforations—and you essentially bleed water, or you could bleed fuel, through the micro-perforations on the outside. You wouldn’t see them unless you got up close. But you use transpiration cooling to cool the windward side of the rocket. So the whole thing will still look fully chrome, like this cocktail shaker in front of us. But one side will be double-walled and that serves a double purpose, which is to stiffen the structure of the vehicle so it does not suffer from the fate of the Atlas. You have a heat shield that serves double duty as structure.
    This technique was used in some rockets to keep the nozzle throat from being eaten away by the welding flame of the engine. In effect he is turning the rocket engine inside-out and keeping the interior cool.
    51,476
    this will never fly on wall street
  3. bwilson4web
    16,102
    Fly into Wall Street?
    51,476
    that would be appreciated
  5. Trollbait
    12,417
    Good thing Space X is private then.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,389
    2,370
    Taylors, SC
    The shell of the Apollo Command Module was composed of two layers of stainless steel with a separate steel "honeycombed" layer brazed in between. The heat shield or "ablation layer" was a phenolic based material harking back to the original synthetic phenol formaldehyde polymer invented by Leo Hendrik Baekeland.
    The original Mercury and Gemini capsules were cladded by "shingle" like overlapping plates made from a nickel alloy designated Rene 41.
    Stainless steel is used because it is less likely to deform in temperatures of 1200 degrees F plus, while aluminum alloys start to deform at around 500.
    Robert Holt and bwilson4web like this.
  7. bwilson4web
    16,102
    A return to Earth requires such a structure. One way to Mars does not.
  8. Georgina Rudkus
    3,389
    2,370
    Taylors, SC
    Examination of man made objects like satellites that degrade in orbit reveals that the majority of debris that survives is made of steel, stainless steel and titanium. Aluminum vaporizes on reentry with a few large dense lumps surviving. Stainless steel is less expensive than titanium and easier to fabricate. Titanium alloys like 6Al4V or Type 5 weigh about .6 as much as stainless steel. The metal in the structure is virtually "paper thin." Stainless steel is chosen on the basis that it can be brazed which results in less distortion than welding. Titanium basically needs to be welded.
    #8 Georgina Rudkus, Jan 23, 2019
    Robert Holt likes this.
  9. bisco
    51,476
    millenium falcon must have been made with miracle steel
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    That would be the miracle metal "Unobtainium", it's much easier to form and use than "Neutronium".
  11. Georgina Rudkus
    3,389
    2,370
    Taylors, SC
    The last syllable -ium is used to name elements. If these are undiscovered, they would be exceptionally heavy and unstable. There are no magical elements in the periodic table. Most all high performance metals would be alloys of existing elements.
    Most all carbon fiber is basically carbon fiber reinforced plastic. They begin to soften at around 200 degrees F. The most temperature stable plastic is PEEK or polyetheretherketone which can operate at around 500 degrees. PEEK is very very expensive.
    Stainless steel is basically cheap and can operate at 1200+ degrees all day long.
  12. bwilson4web
    16,102
    Actually the Wiki article on turbines gives a lot of clues about what can work:
    Turbine blade - Wikipedia
    One open question is dealing with radiant heat. Unless the film coolant is significantly opaque to infrared or the surface reflective, the heat transfer to the surface will be a challenge.
  13. Georgina Rudkus
    3,389
    2,370
    Taylors, SC
    Turbine blades are made of "super alloys." Super alloys have special qualities due to controlled cooling and special grain structure that conforms to the physical structure of the turbine blade.
    The rate of cooling determines the crystalline structure of the alloy. Faster cooling creates finer grained crystals, while slower cooling forms larger crystals.
    Physically working alloys like steel increases hardness and strength and toughness, but also increases "frangibility" or likeliness to fracture and reduces ductility.
  14. ETC(SS)
    7,043
    Good reason to keep the ISS going.....just in case.
    Hey....waitaminute!!!
    Whataya mean FICTIONAL??
    un·ob·tain·i·um
    /ˌənəbˈtānēəm/
    noun
    informal
    noun: unobtainium; plural noun: unobtainiums; noun: unobtanium; plural noun: unobtaniums
    a highly desirable material that is hypothetical, scientifically impossible, extremely rare, costly, or fictional, or has some of these properties in combination.
    KK6PD likes this.
  15. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Maybe Elon Musk is a Neil Young fan. "...flying Mother Nature's silver seed to a new home in the sun..." (from After the Goldrush)
