Stanley Fat Max 700 won't take a charge
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Oct 26, 2019.
  1. Taxi/Limo
    Taxi/Limo Active Member
    509
    107
    This is not a Prius question but I think somebody here can help
    I have a Stanley Fatmax 700 jump starter that won't charge or charges very slowly the compressor is good still but it is
    I am wondering if it is just no good or there is something I can replace to keep it running
    Thanks
  2. tallprius
    tallprius Member
    texas
    Premium w/ Solar Cells
    I had a similar problem with my 5 year old jump box with a compressor. The problem is that there is a small sealed 12v battery inside your jump box. It looks like a little car battery and it goes bad in 3-5 years just like the a 12v battery in most cars.
    Simple fix is to OPEN the box up, note the size of battery and type of posts and buy new battery for the inside of the box (Amazon).
    To replace the battery is 1/2 cost of a new jump box ! NOTE: You have to get same posts to get it to fit in box
    kc5dlo and Pluggo like this.
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    Any idea what kind of battery is in it? Maybe you can open it up and check the battery and -- depending on the kind -- replace it if it's dead. May or not be worth it.
  4. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    How old is it, and how many cycles have you put it through?
    It sounds like the SLA battery is going south.
    Raytheeagle likes this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    877
    Even jumper batteries fail and have limited life cycles just like car batteries. Example: I’ve replace the battery in my Roomba 3 times in its life.
    kc5dlo, Taxi/Limo and Mendel Leisk like this.
  6. Mendel Leisk
    38,700
  7. Taxi/Limo
    509
    107
    It's probably 5 to 10 years old estimate It holds a charge when it will charge
    Can you change the settings on a traction battery fan on a Gen 3 ?
    Thanks
  8. Taxi/Limo
    509
    107
    I can look in to replacing the battery
    The strange thing is it holds a good charge but won't take a charge
    I drained the battery and tried to recharge it as an experiment left it charging for a full day
    and it did not charge
    Is that the battery or something else?
    Thanks all you folks for helping me out
  9. BZzap!
    1,607
    877
    The way it sounds, leads me to think the charge module is no good. You need to do some test to see if the charger might be your problem. It may even have a fuse that’s bad.
    The charge itself is just a normal ac 12v wall charger that’s mounted inside the outer cover.
    #9 BZzap!, Oct 26, 2019
    kc5dlo likes this.
  10. Taxi/Limo
    509
    107
    I was thinking the same because in the past when I wiggled the little plug in deal while in the unit the little charge indicator light would flicker
    I do not know how to test a charge module
    Thanks
  11. BZzap!
    1,607
    877
    You might want try a different cord. See what happens.
  12. Taxi/Limo
    509
    107
    Good idea will try that if I can find one cheap enough
  13. BZzap!
    1,607
    877
  14. Taxi/Limo
    509
    107
  15. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I have 2 older jump boxes that served me well then stopped working. I will dig them out and do some dissecting and replace a battery or 2.
    I have a hand held spotlight that recently stopped working. Rather than tossing and buying new, I just this week tore into it and found it was powered by a single 2200ma 18650 cell. Ordered a replacement 3000ma cell off of Ebay for a few dollars and plan to get it back into service. Dont know why I never thought of replacing the battery in those jump packs. Thanks!
  16. Mendel Leisk
    38,700
    Sometimes battery replacement can rival (or exceed!) replacement cost. I did a battery replacement on a cordless phone set, that was like that. Still, you've kept something useful out of the recycle stream (or landfill...), and it's an item you're familiar with, don't have to have to relearn how to use something new.
  17. Taxi/Limo
    509
    107
  18. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    The battery charges the capacitor, low current/voltage.
    It give a huge burst to the dead battery and usually it's enough to start the car
    in 1 second then the device shuts off so it doesn't damage the small 12v battery.
    The small terminals are not a problem. With the connector, there is only a small portion
    that actually touches.
    Taxi/Limo likes this.
  19. Mendel Leisk
    38,700
    With my JNC660, there's "compatible" batteries available on Amazon, for around $40~60. Clore (the jump pack manufacturer) offers an "official" battery on their website for around $160. That battery can also be found on Amazon, for around $110.
    The specs on the Clore sanctioned battery, amp hours in particular IIRC, are higher than the cheap batteries. This may well be an instance of "you get what you paid for". Considering the new jump pack goes for around $200, and the original batteries seem to last up to 10 years, if/when I'm in need of a replacement I'll probably stick with the sanctioned replacement battery, though I will look for best price.
    nssdiver and Taxi/Limo like this.
  20. Taxi/Limo
    509
    107
    Hello Gentlemen
    I hooked up the new battery from battery sharks
    I plugged in the charger cord to test before I closed the case up
    Nothing happened no lights of any sort and no charge is going in from what I can see
    I hooked up the old battery that still had some charge (I think ) same result
    I am thinking it could be one of four things
    Bad charge cord
    Unit won't function unless case in closed up tight
    Bad Battery
    When I switched connectors I hooked up wrong
    The battery sat around for about three months before I installed it
    What is the problem I wonder?
    Thanks
